Question about Dryers
Can you tell me what fault code E2 on a Hotpoint dryer 9344 means please? It seems as if the heater works for a while but then I think it cuts out and I cannot decide whether to call the repairman or not. It does work a bit but bleeps after about 5 minutes and displays this error code. Thanks Kate
  • katyo Aug 19, 2008
    Thanks, I'll get someone in to look at it then, it doesn't sound too expensive from what you say.
    Brigadier General:
  • 6,966 Answers
To my knowledge, on most brands/models, an E2 error code indicates a a "thermistor failure" This could be indicative that the temperature is too high (which I am assuming is not the case) or the temperature sensor is defective, more specifically shorted (the continuity test reads below 500 ohms).You would need a continuity tester (DVM) to verify this. Should you find it useful, the standard resistance measurements are:
  • 60 degrees F. - 15.3K ohms;
  • 70 degrees F. - 11.9K ohms;
  • 80 degrees F. - 9.2K ohms;
  • a reading greater than 50K would indicate an open thermistor and would display error code E1.
This of course would require opening the unit, replacing the aforementioned part (if tested bad), a fair knowledge of electrical/electronic components and circuitry as said, use of a DVM and safe working practices. If you are uncomfortable with w DIY (do-it-yourself, then perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Tip
Common faults on a hotpoint tdc32
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuitboards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also bethe fault.
For Free Video help on yourHotpoint TDC32 Tumble Dryer USE THIS LINK
on Jan 17, 2010 | Hotpoint TDC32 Electric Dryer
Dryer elements are not heating up
this is the thermostats or the heater has blown. We have a full video library on appliance repair video’s
Common faults -
1 The heating elements can fail (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Dec 31, 2009 | Hotpoint Dryers
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
F10 error code on Hotpoint ctd80. How do I fix ? Thanks
remove 2nd largest panel on back of dryer then remove the heater unit (two small screws) from inside panel,on the top of this you will see two small units with wires going in and out both sides looking closer one of these units has a small hole using a pin push it down into hole this resets thermal cut out,you should hear a small click.
Feb 02, 2009 | Hotpoint TDL15 Electric Dryer
Dont know what the fault codes are for my Hptpoint Dryer CTD80
Hi.
F10 indicates that the heater is open circuit, or the thermostat is faulty, more likely to be open circuit thermostat, you should replace both thermostats.
Also make sure that you clean the filters regularly
This should solve your problem.
Nov 20, 2008 | Hotpoint Dryers
Wd640 hotpoint washer dryer - error code F03
This indicates that the wash thermistor is "Open Circuit" and I think it is situated on the heater assy at the back of the machine.
Check the wiring and contacts between the thermistor and the PCB. If you still get the fault it could be the Thermistor ( which means replacing the heater ) or a faulty board.
If it is under 5 years old - Call Hotpoint as you have a 5 years Parts Guarantee mind you the call out is £89.98 but thats cheap if it happens to be the board!
Mar 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
131 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
