Question about Epson Stylus RX580 InkJet Photo Printer
Epson RX580 can't change ink cartridge
I bought some compatible ink cartidges and the printer starts up but gives a warning "The installed ink list above is not ..."
The message seems cut off a this point.
The Continue prompt appears with the upside-down triangle but pressing the "Stop/Clear Settings" or OK buttons gives no response. It seems hung. Is there a mechanical interlock I can use to get at the print head to remove the cartidges, or how do I get it to continue and accept the cartridge?
Thanks!
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Well..sounds like your new print cartridges are not too compatible..I recommend you get the right ones
Posted on Aug 19, 2008
Hi, I have a Canon MP620 printer and I bought compatible ink with a chip. I installed it and there is an error u140 which states that it does not recognize the cartidge. Would appreciate it greatly if...
Hello!
Here is your solution.
1. If your replace only one cartridge follow the step. = Press Stop/Reset button for 5 seconds............. after that your printer will start its process. 2. If your replace both cartridge follow the step: = Press Stop/Reset button for 5 seconds ............ after 5 seconds wait for few seconds. Your printer will show the same error, so press for 5 seconds again.... thanks
Sep 14, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I have installed a refillid cartridge into Samsung fax machine SF-375TP and I get message"Install ink cartridge".What must I do in order to get machine to start working again?
Many cartridges DO NOT respond well to being refilled, and if you don't use a manufacturers ink cartridge. And if you don't you will get that message.
Sometimes you can reset the "Chip" in the cartridge, yes, there is one in there too, especially so it cannot be refilled by a third party,
There is NO simple way around this, "They" want you to buy NEW inks each time, and NOT refill, it sux huh?
www.crowson-ward.co.uk/media/pdf/Samsung%20SF375TP.pdf
Manual above.
www.futuregraphicsllc.com/lit/instructions/CLPCRSTECH_ud.pdf
Above is a link on resetting the cartridge.
Aug 04, 2010 | Samsung Office Equipment & Supplies
I bought hp 98 ink catridge from Walmart for my hp psc 2355 printer. when i installed it the printer gave me incompatible error. I went back to walmart to return it and they said the hp does not allow...
Try to sell the ink cartridge through 'www.CraigsList.com' or 'www.eBay.com', or find a "FreeCycle" mailing-list, and give it away.
Or, buy an HP printer that *DOES* take the "98" cartridge. :-)
Nov 09, 2009 | HP PSC 2355 All-In-One InkJet Printer
I bought epson compatible cartidges but my printer cannot read them even after downloads ssc, any ideas????
I have also attempted compatible cartridges for an Epson printer. It would give warnings about not being compaitible and they didn't print ideally especially for photos. I think it's one of the cases where you may have to bite the bullet and pay for the Epson cartridges.
Oct 03, 2009 | Electronics - Others
New color ink cartidge won't work
Did you remove the tape on the bottom of the cartridge before you installed it?
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printer cannot recognize ink cartridge
Check the PG 40 & 41 Labels are near the top lugs and not near the curved lug and make certain that the cartridges are fitting in right. If the label has slipped down the 'chip' can not be read and error message will come up.
Mar 20, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP520 cartridge swap and ink refill
Canon MP520 multifunctional device - deactivation of the ink level counter
1. You can do it only when the printer counter releases the warning message - "the ink cartridge is nearly empty" = yellow warning mark
2. You have to do this procedure four times - for every cartridge one times
3. At the screen you will see three warning messages
- for the first one press "OK"
- for the second and third one press "Yes"
4. The fourth message tells you that you can do the ink level counter deactivation by pressing the "Stop/Reset" button (7) for more than 5 seconds. Do it.
Later you can see another type of warning message at the screen:
In this case you can not follow the previous procedure - there will not be any other warning messages.
Just follow the message on the screen and press the "OK" button (5) and you can print.
Unfortunately - I do not know for how long time it works.
You have to manualy check the ink level and refill (change) the cartridge before it is completely empty! You might brake your warranty!
When you insert the new original ink cartridge, the counter will work properly again.
Jun 08, 2008 | Canon MP520 All-In-One InkJet Photo...
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
Epson Stylus RX580 InkJet Photo Printer Logo
133 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
