Question about Zanussi ZCE7551X Electric Kitchen Range
Element Hi there is the element a costly part to have fitted its needed in the main oven part
    President:
  • 2,692 Answers
No . Very reasonable. Common item at appliance parts places and not difficult to replace. Have you tested it with a light or ohm meter to see if it is bad? You will have to disconnect it to do so.  If you need more infor , just ask.
Posted on Jan 03, 2009
Diplomat ADP 5520 Stainless Steel Range not getting hot enough
The circular element that the fan sits behind heats the oven. Ensure the thermocouple is back in the right place. Too near the element and the oven will stay cool.
Circular elements can be pricey and fitting should cost no more than an hours labour.
http://www.espares.co.uk/search?SearchTerm=ADP5520%20element
Jun 23, 2017 | Ovens
Hi, my CK440 main oven just stopped working
Had similar fault most likely to be the main oven lower heating element access from back of oven. Main contacts to the element have possibly broken down causing a earth fault which will trip your the RCDs on the consumer unit.costs about £35 to replace using approved Kenwood parts.
Mar 17, 2010 | Kenmore Kitchen Appliances - Others
How to replace element on my Hotpoint main oven BD31
If it is the main oven element, then undo the screws that secure the cover at the rear of the oven, remove cover, and you will see the round element there.
Undo screw securing element, and pull forward in to oven compartment.
Detach the wires, and fit new element.
Hope this helps you.
Please leave feedback.
Thankyou.
Jan 06, 2010 | Hotpoint Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 | Ovens
Hi need a manual for a select 920 diplomat oven
I have a Hygena 920 twin oven and grill .The electrical element in the grill started to droop several months ago, now it has stopped working . the element has burnt through. Could this have caused a fire?
I should like to know if it is possible to get a spare element and fit it myself. What would be the cost of the element? Thanking you in anticipation.
Mr J. Walden
Sep 02, 2009 | Ovens
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Neff U1661 main element doesn't heat up
Hi.
Yes ,it is the element.
You need to remove the panel at the rear of the oven, this will give you access to the element.
Good luck
Nov 21, 2008 | Neff U1661 Double circotherm super...
No heat in the main oven
Hi
We had the same problem - turned out to be the fan oven element - simple to fit - remove the back plate around the fan (6 screws) to expose the element. Remove screws securing element and disconnect wires (mark wires before removing) Our replacement was £40, but take the original as there are quite a few variants - you will also need the full ENR number (on side of housing) However, be aware that if this does not work, the thermostat may also have blown with the element. We were lucky as replacing the elelment fixed the problem.
Nov 26, 2007 | Neff U1661 Double circotherm super...
Main oven not heating up
fan oven element has gone. it is a circular element and is located behind the back panel of the oven. some elements can be removed with the oven in place but for many you have to take the oven out and take off the rear casing. whichever, it is not a difficult job. element cost about £30
Mar 29, 2007 | Electrolux EOU5330X Ultrafan Electric...
Zanussi ZCE7551X Electric Kitchen Range Logo
235 people viewed this question
Top Zanussi Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
