Need to reset bios password for acer 4620 laptop. tryed removing battery on mb . no good . ? passmord bios
  • adaliz Sep 03, 2008
    I am trying to remove the BIOS password and the machine, before reboot, appears the screen with a password. I thought that I removed this password but don't. I try to enter the current password and appears a message of System Disable after three tries.
    Thank you
    Rosa
  • hello--2009 Nov 25, 2008
    i have a laptop and it is closed i need a help haw can get a password bios
    and thank you
    please how now a solution send me to my email
    [email protected]
  • Computers & ... Master
  • 32,281 Answers
Try removing the main battery and the CMOS battery (ie the battery on the mb). If you don't want to wait for 1/2 hour for the CMOS to discharge then short out the CMOS battery connections with a bent paper clip.
Then without instralling both battery, power up your laptop, you should then get into the BIOS, power off and re-install your batteries.
Posted on Aug 19, 2008
First DONT DARE PUT IN FRIDGE.
you need prog to reset bios password or jumper reset on mb.it reset cmos settings.be carefull!. go to acer site or a forum.you will be suprised how many people have this problem.
SOURCE:
I had a acer company laptop model extensa 4620 . probbem a bios password and c; access dinied . bacause i am not remeber bios password. so ple, sowl my pro.
You can reset the bios password fairly easy. You will need to unplug the laptop from power and remove the battery pack. Then you will need to turn it around and you will see a cover plate. Remove the plarte and inside you will see a little flat battery. Just remove it and replace after 2-3 mins. Then close up and replace battery and restart. Should have cleared the bios.
Hope it helps
Jul 23, 2011 | Acer Extensa 4620 Notebook
Dear... can i have solution for my laptop acer extenza 4620..if i open bios ,he need password..can u help me what solution for open bios password..thanks
You have to pull the cmos battery from the board. It is the only way to reset the password. Some manufactures back a backdoor password they do not share with the public though. Only real way to is to pull that battery.
Mar 10, 2011 | Acer Extensa 4620 Notebook
Helo, i,m in a greate trouble. i forgot my laptop acer extensa 4620 bios password. and now i could,nt install any operating system. cause i need to change the boot device from bios. i,ve tried a lot. but...
im sorry to hear that but unfortunately, if youre not the one who created the BIOS password, theres no way for you t acces it anymore, what you can do is to reseat the CMOS battey on the motherboard so that BIOS password will be reset.
Hope this will help...
Jan 19, 2011 | Acer Extensa 4620 Notebook
I have forget my bios password,i removed my batery but i am still having same problem.
hello there!!!
there are many ways to remove or bypass bios password!!!
1. removing battery to drain the data in bios memory
2. short the jumper of the bios mostly found at the lower side of the memory slot.
thanks
Jan 03, 2011 | Acer Extensa 4620 Notebook
Reset bios password
To reset the BIOS password on your Acer Extensa read the information from this link.
May 15, 2010 | Acer Extensa 4620 Notebook
Password bios of extensa 4620z
You should be able to remove the password from the CMOS setting.
Just select F1 at boot up and locate the password section once you are in the CMOS Setting then clear it .
Regards
Feb 25, 2010 | Acer Extensa 4620-4648 Notebook
I want to reset bios password.
what you need to do is to remove the CMOS BATTERY for some seconds/minutes and then replace it. This brings your machine to default settings and then you can enter a new bios password.start your computer then press F10 for setup/Delete for other machines and then go to bios settings and set a new bios password.In addition to this you can also clear the bios password by removing the shunt on the cmos jumper then plug it other way round, remove it again and then plug it as it was at first.
Feb 01, 2010 | Acer Extensa 4620-4648 Notebook
The computer locked and I can not unlock because it won't let me type inn my password. no letters appear when I type. Acer extensa 4620-4431
For security reasons, some laptops do not show passwords when you type them on the password page.
For your own case however, I would suggest that you should just try and reset the Laptop Password to its default settings by removing the CMOS battery. This means you might have to unscrew your laptop at the back, and try to locate the CMOS battery, remove it from a few seconds and replace it. This method will automatically reset your password to its factory settings.
If you cant unscrew your laptop by yourself, you can easily get a technician to do it for you.
Hope it helps you out.
Jul 13, 2009 | Acer Extensa 4620-6456 Notebook
call tech support and they will give you a recovery disk but it clears all files you saved but if you have this disk then you can use that or when you start up your computer it should say something like system recoveryf10 or something like that
Jun 22, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
1,234 people viewed this question
Ekse
Alun Cox
