Question about Cameras
Sony Cyber-Shot T9 when memory stick inserted it comes up reinsert the memory stick Please help me
Oh boy, I just tho't I had a bigger problem. When I read a comment that it could be a contact problem, I removed the stick & rubbed the contact points on a soft cloth, blew into the space into the camera that holds the memory stick to clear any possible dust, etc., and it worked! Good luck.
Posted on Nov 01, 2008
Memory stick for sony cyber-shot
You might try cleaning it with alcohol.
If that doesn't work you'll have to insert the card into a pc and use some kind of data recovery software to do that. I would recommend R-Studio or Get Data Back. Unless you know someone that could do it for you.
Nov 04, 2007 | Sony Cyber-Shot DSC-S50 Digital Camera
My sony keeps saying Reinsert the memory stick?
The error message "Reinsert Memory Stick" may occur due to the following reasons:
1. The inserted Memory Stick media is not supported for use with the Camera.
=Ensure you are using the supported type and capacity of Memory Stick media for use with the Camera.
Please click on the below link to check for the compatible Memory Sticks with the Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12
2. The terminals on the Memory Stick media are dirty.
=Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up.
3. The Memory Stick media is damaged.
=Use different Memory Stick media and check if the issue persists.
Mar 05, 2010 | Sony Cyber-shot DSC-W190 Digital Camera
Hi, just bought sony cyber-shot dsc s930 and evrytime i turn it on it says "reinsert memry stick" but nothing happens it just keeps saying the same thing. can you help
Did you format the memory stick in the camera before trying to use it? Are you able to get into the camera menu to do that? If not, try removing the stick and battery...press all the buttons...leave it alone for 20 minutes...insert the stick and then the battery...turn it on.
Jan 07, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Reinsert memory stick --- I have removed battery and memory stick with no result. Help
Sony says:
Article ID : 101488 (modified 10/29/2009 03:18:00) Question: A warning message appears on the LCD screen when a Memory Stick is inserted into the camera. Answer: The following could be possible causes for the error message to appear:
  1. Verify that the Memory Stick is inserted correctly.
  2. The inserted Memory Stick cannot be used in the camera. Refer to the related link below for compatible Memory Stick.
  3. The Memory Stick is damaged.
  4. The terminal section of the Memory Stick is dirty.
http://www.sony.com.ph/support/faq/101488/product/dsc-w190/modelfirst
Jan 02, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
Sony cyber-shot DSC-T9
Yes, other way is to format memory stick and format option is in Menu. Format will delete every thing on memory stick and refresh it for new pictures.
Apr 23, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Keeps telling me to reinsert my memory stick
I will forward a link to a page where you can get the information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C166567
Also please check whether you're using a Compatible Memory Stick with the Camera.
It's not recommended to Format the Memory Stick in the Computer.
The Memory Stick should be Formatted in the Camera only, other wise such error messages can occur.
Please try using a different Memory Stick and check whether the issue persists with the other Memory Stick.
This is to check whether the issue is with the Memory Stick.
Apr 14, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
Memory Stick error c:13:01 My old 512 MB memory stick is working fine. However, recently I brought a 2 GB memory stick and when I put it inside, the camera (Sony DSC S40 cyber shot) shows: MEMORY STICK...
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Nov 30, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
No piks showing
The memory card can't be more then 2gb...the camera won't support more than that. Have you formatted the memory with the camera? If not try that, don't format the card with your computer.
May 05, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
DSC H9 Memory stick
Try formatting the memory card with your PC and an external card reader and then try again.
Mar 27, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Cameras Logo
1,390 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
