Question about HP PSC 2110 All-In-One InkJet Printer
Unit failure My XP Media Edition PC does not recognize my HP PSC 2110 even after complete removal and reinstallation. The printer also will not print a self-test report or do a scan but will occasionally make copies. I have tried changing ports and cold restarts of both computer and printer. Am I doomed to replacing my printer?
  • Bill Morgan Aug 19, 2008
    Spot on. I subsequently ran diagnostics with an online tech rep for HP and we agreed that the five year-old hardware was just worn out. No simple tricks to make it work again, just a trip to printer graveyard.
  • Bill Morgan Aug 20, 2008
    ...but the beat goes on. I had left the printer unplugged overnight and powered it up again to see if I could squeeze out just one more copy. It fired up and operated perfectly normally! Don't know how long it will last but I still have a replacement on the way.
    Perhaps an extended disconnect might be a good recommendation for others??
    An expert who has answered 500 questions.
  • 564 Answers
Posted on Aug 19, 2008
  • Patrique Davenporte Aug 20, 2008
    sad to see..give it a decent burial, and use my name in the invocation.
    also, you may wish to keep that link handy for other printer issues.
    coolness..may be a close encounter of the 5th kind, eh?
I have a hp psc 2100 and it will not print. I have rebooted, uninstalled, restalled and when completed, the printer either reads "scanner failure, turn off, turn back on" or "printer test...
Hello,your scaner seems dirty,first open the control pannel by pull out the cover then you will find some slots after removing the cover you will find a mark push them & push the pannel to down ward remove the cable from connectors.
open all the screws remove the cover over the glass & over from scanner assembly,take out the scanner assembly from printer .
After removing the scaner *** open them & clean inside ,reflecting mirrors & lence by a soft cotton refix them as open,
Note one thing the home position sencor situated as white strip insidephase of flatebed scaner clean also then .
Refix the unit as open carefully your problem will be resolved 100% ,altough it persists then replace the flatbed scaner.
Pls comment whether it works or not ....................regards... jitendra
Dec 18, 2010 | HP PSC 2110 All-In-One InkJet Printer
I have an hp psc 2110. I made some enlarged
Some basic steps to begin with:
1. Disconnect the printer from the computer and power off then back on. In some cases the problem can be caused by the print spooler on the computer.
2. If the problem persists, power off the printer and remove the power adapter. Leave the printer sit for 10 minutes or so, allowing the internal memory to clear, After which you should hook the printer back up and reconnect to the computer.
Finally determine if the printer is being recognized, on vista or windows 7 you can do this by clicking 'start' >> 'devices and printers'... or on xp 'start' >> 'control panel' >> 'printers and faxes'
If it is not listed as connected on the list (ie. offline) try uninstalling the printer and rerunning the drivers.
May 25, 2010 | HP PSC 2110 All-In-One InkJet Printer
Put in new cart. in 2110 psc it says to remove and check cart.won't accept and operate
OPEN THE TOP UNIT.remove the cartridges .you can see metal contacts in the printer carrage unit.clean the contact with soft tissue cloth.
Oct 24, 2009 | HP PSC 2110 Color Printer
Right when i turn it on it makes noise hp psc 2110
Dose it work?
My hp 750 dose this and even talks when not working.
You can get HP Print Diagnostic Utility software which will fix most hp printers issues.
R Miss Brooks
Sep 02, 2009 | HP PSC 2110 Color Printer
HP scanner will not scan, but will print
reinstall drivers and restart the whole system
May 07, 2009 | HP PSC 2110 Color Printer
Copy problem w/ Windows Vista
For a complete set of instructions on copying with your printer, please click here
If that doesn't get you there, let me know the specific error you're getting and we'll sort it out!
Apr 20, 2009 | HP PSC 2110 All-In-One InkJet Printer
Hp psc 2110 won't work in vista
Vista has the drivers for the HP psc 2110 embedded in the OS.
So, you should be able to print, with the default drivers. But, you will not be able to scan as of right now, unless someone releases an update for the HP PSC scanning software. I doubt that will happen, as these all in one's are so old.
Such a good little printer/ scanner/ copier too.. kind of sad to think its that obsolete that its not compatible for scanning.
Jan 19, 2009 | HP PSC 1210 All-In-One InkJet Printer
Document fails to print
Power the unit down for an hour or so. If still a problem
Uninstall the software and then reinstall software from the CD.
Mar 27, 2008 | HP PSC 2110 Color Printer
HP psc 2110 all-in-one wont print from internet
I'm assuming you went to the HP site and downloaded the Vista drivers??? Other than that try this:
  1. From Control Panel > printers... uninstall all printers.
  2. Unplug USB cable to printer and re-boot.
  3. Install Software.
  4. Plug USB cable back in.
Hope that fixes Ya...
Mar 26, 2008 | HP PSC 2110 Color Printer
HP PSC 2110 All-In-One InkJet Printer Logo
75 people viewed this question
Ben Johnson
