I want to get the metallica sound from my marshall AVT50
  • 3 Answers
Use the high gain channel. Set the bass to 8-10 set set the mids to 6-7 and the treble to taaste to cut through. Also turn the contour all the way up. To gice that scooped mid sound. Or use the celan channel on the amp and run a boss metal zone pedal through it. Set amps clean channel EQ to flat ( at 5) and the metal zones controls. Treble to taste for a good bite, bass up to the point were it wont fart out on your amp, sweep the mids outer knob set about 5-7 and the inner knob to about 4. Set prescence for clearity and the distortion level as high as you can stand it.
Posted on Aug 21, 2008
Marshall mg15fx. no sound coming. the only sound i get is buzz when switching the master knob.
I would test by first trying a different guitar cord. If the fault is still there, try jumpering the effects in and out jacks with a patch cord. If there is sound now, clean the two jacks with contact spray and working a 1/4 inch plug in and out of the two jacks.
Jul 04, 2014 | Marshall Amplification Marshall MG15 15...
I have a marshall mb150 and sometimes it used to stop emitting sounds for a while but now in the sounds gets deemer and louder every now and then
A common issue with Marshall Amps are generally speaking a low resistor value cracked leg inside the power module, just open up the amp and with the amp unplugged from mains check by a little finger movement the big 2/3W resistors and possibly you will find that one or other will have a broken leg, also cold solder joints do this kind of issue, hope this helps...
Oct 09, 2013 | Marshall Amplifiers Marshall MB150 150W...
Can i connect 2 (2x12) cabs rated @ 4ohms each to my avt50 head?
No, the ATV50 head is rated for 4 ohms total. Using both 4 ohm cabinets at once will fry your amp.
Feb 12, 2013 | Marshall Amplification Music
No, the ATV50 head is rated for 4 ohms total. Using both 4 ohm cabinets at once will fry your amp. Your only option would be to rewire your cabs internally to 16 ohms each by connecting the speakers in parallel, but that would cut your amp's power in half.
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
81 people viewed this question
 Grubhead
Grubhead
