Question about Xerox Phaser 8560MFP Laser Printer
Printing Black & White
Xerox Phaser 8560MFP - Is it possible to print in black and white when one or all of the colours have ran out?
  • 48 Answers
Sure..but you need to set that in the settings of the documents printing under default(use greyscale).
Try this link for more Printer Resources
Posted on Aug 19, 2008
SOURCE:
Is it possible that a print driver may have caused my printer to stop printing black
Try printing an internal print page like the configuration page. If the page is printed in black and white then there is a problem with the printer. If the page is printed in colour then the printer is fine and the problem is with the driver or the driver adjustments.The driver itself can not cause a permanent problem to the printer.
Sep 19, 2014 | Xerox Phaser 7300N Laser Printer
How do you fix the colour printing grey instead of black
Do you need to change out your black color cartridge? Check your ink levels to make sure that you have plenty of each color. Also, check the settings for your printer (perhaps under "properties") and make sure that you haven't clicked on "grey scale". I hope that this helps.
Jul 15, 2014 | Xerox Phaser 7400/N Printer
Even when all properties are set to 'black & white' our Phaser 8550 won't print without all ink colours LOADED. How do I bypass this need so we only need/use black ink?
Only loading black ink and printing monochrome only is not an option on this machine. It must have color cubes installed to keep printhead purged and operating normally.
Sep 03, 2013 | Xerox Phaser 8560DN Laser Printer
Xerox 7328 not printing in color
Ensure that you are intalling the correct print driver, www.xerox.com, support section.
Also check to make sure that the colour option in the printing preference is not set to Black and white or grayscale.
Also ensure that you dont have any accounting option set to black and white only.
Dec 28, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Set default to black and white
This should be in the advanced tab in printing properties.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Mar 07, 2012 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
I just got a 8560MFP and I am running win 7 64. I can not get the printer to print in colour only black and white, and advise/help?
in your printer driver, Start/printers & Faxes.. Right click the printer Icon for your 8560 and goto properties.
Goto Advanced Tab and then Printing Defaults..
Make sure the Black & White printing is Unchecked.
Jan 14, 2011 | Xerox Phaser 8560MFP Laser Printer
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
Dec 09, 2010 | Xerox Phaser 8400 Laser Printer
Out of magenta toner, but need to print in black
normally most printers when you select properties and advance you can select the quality of printing there you can select grayscale instead of color that will do it
steps
click start printers right click properties for pinter select advance change the settings. print a test page will come only black if not repeat steps.
Jul 26, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 8560 mfp Printing issue
That really sounds like you need to replace the maintenance kit.
The white roller most likely is black and has depleted itself of lubricant a bit prematurely.
May 21, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
619 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
