There seems to be a fault with the connection on my 3.5mm audio-in port (intermittent signal). Is there an easy fix for this or would it be better for me to look at an alternative for my audio-in (3.5mm to USB maybe) ? THANKS Richard
Via trial and error really I enabled the "line-in" socket in Sound settings and it works OK. I also enabled the Dolby Virtual Speaker and this now gives me both channels from my 3.5mm audio-in jack socket...thanks. Sharon.
Posted on Aug 20, 2008
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
Purchased a LGE2050T monitor, wish to connect to tower to get audio; no audio points on monitor
As I can see from the monitor specifications there is no audio connectivity. This means that there is no audio 3,5mm jack for the audio from the pc to feed into the screen. So you have to use an external audio system (speakers) for the audio.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 01, 2011 | Computers & Internet
I just got a multimedia surround system with subwoofer.Spa7650/05, 180w.The subwoofer has three audio connections,front,centre and rear,My tv only has an audio coaxial.I can't connect it.What adapter...
Firs of all lets get agree on something..The subwoofer has three audio connections for "output " to :front,centre and rear speakers...these are not for "input"..Your powered SUB provides necessary signal for other spekers..
You can connect TV audio coaxial to SUB input with a RCA cable.....if your SUB does not have "RCA input " probably it should have "3,5mm Haedphone female Jack"..
if this is the case you need to buy a cable ; one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Philips Audio Players & Recorders
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
When I plug my PS2 or VCR into the back of my TV using red, white (audio), and yellow (Video) cables, the picture is grey and fuzzy. I have plugged the yellow into the far left port marked "Y". I...
Yellow is a composite output and should be plugged into a composite input, whereas Y indicates the COMPONENT input of the TV. If you don't have a separate composite input use a scart to phono (rca) adapter in your tv's scart input.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 04, 2011 | Insignia 42" LCD Flat-Panel HDTV
Audio connections and video seem to be making bad contacts. The mics work intermittently and video intermittently works when wires are jiggled. Using cordless mics with reciever. When reciever is connected...
Sounds like you have a bad set of jacks. This typically occurs when the female ports on an electronic device begin to fail. The inside of these audio and video ports have a contact pin that the male connector comes in contact with when inserted into the female port. A little adjustment of the female pin connection will usually do the trick. You may also want to check the solder joints or connections.Sometimes they begin to break and lose contact.
Hope this was helpful. Good luck.
Apr 03, 2010 | JVC XL-MV303 CD Player
Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
Make sure you have an anteena connected and adjusted
Jan 29, 2009 | Denon AVR-1802 Receiver
Problems with TV volume intermittent dropout
I fixed my problem by turning off the Bass Boost on the TV. Not sure if there is a problem with Bass Boost itself, but it sounds much better now.
Jan 16, 2008 | Panasonic TH-50PX75U Plasma HDTV
18 people viewed this question
 Grubhead
Grubhead
