Question about HP Pavilion dv6000z Notebook
Virutal memory I am using HP pavilion DV 2000 laptop. It is displaying "Virtual memory too low" message and operating speed has reduced drastically. I have deleted all temporary files, defragmented files but no result. Please let me know the solution to this. Thanks,
  • 108 Answers
Try this.
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Posted on Aug 19, 2008
SOURCE:
How do you stop the low memory window from coming up on an HP Pavillion dv 2000?
Hi friend,
You need a much space for use window. when system is running any file then system need much space for running...you could free some space in your C: drive.....if you don't have any space in c: drive ...you can use disk clean up for delete the temp file....do it
Dec 31, 2009 | HP Pavilion dv2000t Notebook
I was on the internet the other night an a popup said that my memory was low so what should i do an its really slow...
If too many applications are running in the background memory is reduced. Verify that you let Windows manage the paging memory.
For WINXP
Rigt click My computer on desktop.
Click Properties
Advanced Tab Click on Performance Settings.
Under Visual effects you may ask OS to adjust for best performance Under Tab Advanced make sure that Processor scheduling and Memory usage are set for Programs.
Verify on same tab that virtual memory is about equal to physical memory (or just let windows manage it)
Hope it helps
Sep 13, 2009 | HP Pavilion MX70 17" CRT Monitor
Its hp pavilion dv 2000 notebook i on power no display but i hear 3 beep sound only how to service
The 3 beep POST code error means there is a problem with the memory, could be faulty or just needs reseating.
Reseat the RAM modules and if this doesn't work then remove the memory module/s and take them to your friendly computer shop to test them.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
Virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
My HP Pavilion laptop will not boot.
Usually the message about low virtual memory is because there isn't enough RAM and it was using up all the designated space on the hard drive as Virtual memory. (Uses a part of the hard drive like RAM)
That shouldn't account for being unable to boot into any Windows options though.
The one trick with HP computers, you can try is to take the battery out, make sure the Laptop isn't plugged in with an AC adapter then press and hold the power button in for 10 seconds with no power going to the laptop. This is doing a power drain. Then put the battery back in and try to power on and boot up the computer.
When you choose safe mode, does the computer ask which operating system you want to boot into and does it give you the option to choose "Recovery Console"? Or is there an option on the screen with the safe mode options to Choose your Operating System? If not then the recovery console wasn't installed. If you can choose the recovery console, you might be able to replace the failed files that are not allowing the computer to boot into any version of Windows. Unfortunately, the computer isn't reporting which files are the problem, winlogon.exe/userinit.exe/etc.
You can get a hardrive enclosure at a computer store that allows you to put the laptop hard drive in the enclosure, then plug the enclosure into another computer with a USB cable then you can copy the sensitive data onto the other computer.
If you aren't comfortable taking the Hard Drive out yourself, you can take the laptop to a computer store, and they will take the Hard Drive and hook it up to a second computer as a Slave (Secondary Hard Drive) and copy the data over for you
Apr 12, 2009 | HP Pavilion dv8000z Notebook
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Virtual memory low
naz2172, Buying memory is always a good idea.
Buy as much as your laptop can handle, to eliminate your problem.
Feb 19, 2008 | Computers & Internet
Vitual memory low
free up more disk space. delete unescessary files on your windows drive.
Sep 16, 2007 | Microsoft Windows XP Professional for PC
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
