Question about HTC S620 Smartphone
S620 Using GPS with Memory Map software
My S620 identifies my bluetooth GPS receiver (Blue Next) but will not use the info it sends. The GPS unit works well with my laptop and Dell PDA.
A solution would be much appreciated. Thanks.
In the Comm Manager, select Settings, then Bluetooth.  Again select bluetooth and then scroll down to your GPS receiver assuming you're paired correctly.  Click Menu and then COM ports.  Now click Menu and select New Outgoing Port.  Pick COM6 assuming you have nothing else on this as your outgoing port.                   Now go back to your map program.  In the GPS settings, select COM6 as your GPS and it should now give your position.  I use google maps and have no bother.
Posted on Jan 19, 2009
SOURCE:
Avic s1
hello sir,
Portable Smart GPS Navigation comes with 3.5-inch Touch Panel Display, 2GB Flash Memory, Bluetooth Wireless Technology, and Scroll Wheel
  • 2GB Flash Memory contains the map data of entire US and Canada
  • Just unpack and use it � no PC connection is needed for startup
  • Future map data updates will be available by SD card � just load into the built-in SD card slot and the update will begin
  • Quickly set a destination by address, zip code, destination history, and more
  • Search for a gas station, restaurant or coffee shop using the POI Search � destinations are sorted into categories for short-cut searches, or use the touch screen to type in the name.
thanks for allowing us to help you
Dec 30, 2007 | Pioneer AVIC-S1 GPS Receiver
I have no maps on the screen its like i lost all the data. it says there are no roads near this start point. every thing else works mp3, settings, volume, bluetooth, etc.
it sounds like you may have just deselected the maps.
go to tools settings map then map info(bottom of the screen)
check that there is a tick next to your mapset if not just tap the name of the map and you should be sorted out.
Jul 12, 2010 | Garmin Nuvi 660 GPS Receiver
Ihave bought a new, still in the box Magellan triton 200 unit and usb cable for geocaching. unfortinitly it wont send co-ords from my pc to my gps unit. i am using windows vista basic. why does it not...
First of all .. you must install Vantage Point to connect correctly from the PC to the GPS and also synchronize map on VP to PC map. Next you must use a scrubber like GSAK to remove garbage in the cache information. Then do you transfers to the GPS.
Jun 01, 2010 | Magellan Triton 200 Handheld GPS Receiver
How do I install maps from the Garmin US Topo 100K to my Garmin Etrex Vista HCx? I've put in a microSD card, then what?
You need to install the map software on your PC. From there, using the map select tool, select the maps you want to add to your GS unit and then send them to the microSD card which will show up in the SEND window.
Mar 29, 2010 | Garmin eTrex Vista HCx Handheld GPS...
Looking for free maping software for garmin 360 GPS also need it to be able to identify 911 address.
Unfortunately all map software is copyright protected by Garmin, so you need to get it from them. Attempting to download a newer map off a different unit will not work, as you will also need to generate an unlock code which is initiated by internal serial number of the GPS.
Jan 09, 2010 | Garmin NUVI 360 GPS Receiver
Sat Nav, Online mapping not good
Check out the Terracrosser software, this uses Google maps but allows you to use downloaded maps. Terracrosser works on my S620 although I haven't been able to get my BT GPS unit to function properly with any mapping software. I have tried setting it to COM 6 as previously suggested.
Jan 29, 2009 | HTC S620 Smartphone
Downloadig from memory map
Is Mapsource installed on your PC?
Are you using the "Receive from Device" icon?
Is your unit being recognized when you use "Receive from Device"?
If your answers are yes to all of the above, you might have to update your Mapsource programme (free of charge) from the Garmin Website. Also, updating your unit software from the Garmin site is also a good idea.
Please let us know if this fixes your problem.
Apr 05, 2008 | Garmin eTrex GPS Receiver
Garmin NUVI 660 BlueTooth
I had the same problem, and this is how I fixed it. Now it's working fine.
Thank you for contacting Garmin International,
If you are currently running the most current version of bluetooth software, and you are still seeing issues where your compatible phone is still not connecting properly, please try the below procedure, which will reinstall the version of bluetooth you have downloaded in case there was any corruption during the transfer or installation of the bluetooth version.
1. Power the unit on
2. Touch View Map
3. Touch the ETA/Speed button in the bottom left hand corner.
4. press and hold your finger over the speedometer for 10-15 seconds until a new screen appears.
5. Touch next at the bottom of the screen until the top blue banner reads Bluetooth Status.
6. Touch UPDT P, then Touch yes.
7. At this point the unit should go to a page that says Updating Bluetooth Firmware, allow this to finish, once finished, press quit, then press and hold the back button. At this point, go back through and try to connect your Bluetooth device again.
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
HTC S620 Smartphone Logo
311 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
