Question about Gateway FPD2185W 21 in. LCD Television
Dead screen How to open fpd2185w Gateway monitor
  • 1 more comment
  • fotonana Sep 02, 2008
    my screen goes dead also.......blue light in front sometimes flickers, but this is not usually the case.......can't turn it off either. I called Gateway, but was just a couple of days out of warranty.
    I need help.......terriffic monitor otherwise.
    MHerr28553@aol.com
  • lnxu2000 Jan 14, 2009
    We have exactly the same problem for more than 10 pieces of the 70 pieces of this brand/model LCDs that we purchased a year ago. Gateway hired a company (MPC) to provide warranty services, however, MPC totally went out of business recently for bankrupcy. All the warranties are gone, too.
  • Falling star May 11, 2010
    for me its been helpful to place the monitor with base removed on its back with the button facing to sky. and starting on the bottom corner with a small flat screwdriver pry up a corner. I used a black comb to keep it spread without marring it, but if you use 2 screwdrivers you can do the same. Im haveing trouble with the top side and top half though suggestions? (oh and make sure to do this when the plasstic is warm so it will flex a little instead of break!)
There are 3 screws at the bottom of the unit. Take those out.
At the bottom get a small screwdriver and slowly start to push inbetween the plastic. there are tabs all around the side of the unit. You have to be careful and push in and it will snap open.
There isnt too much cable for the power switch, so you will have to disconnect the cable. this will allow the rest to open up.
Once you do this, 4 screws hold the LCD in place, remove these. Carefully from the bottom pivot the LCD screen. On the right hand side 4 connectors will need to be unplugged and one main cable on the left had side. Be careful not to damage the socket.
There is a metal enclosuer that has to be removed, once done open the top and remove the power board. There are about 12-14 capacitors that if you replace them. The unit should power up.
Posted on Aug 22, 2008
    Guru:
  • 196 Answers
Ive found that by lifting from the inside of the 2185 the part next to the screen that it comes up eaiser. you will need a little screwdriver flat to be able to take the on and off cord out of its socket my hands were too big to be able to reach it.
the screen has 4 screws that hold it in on the sides, note that by these screws there are raised plastic round knobs that stableize it. so when you lift it out do it from each side evenly not a tiping manuver.
Posted on Jan 24, 2009
3 Suggested Answers
  • 191 Answers
SOURCE: Gateway FPD2185W monitor turning on problem
change ur inverter
Posted on Nov 10, 2008
SuperTech-11
  • 1591 Answers
SOURCE: Gateway FPD2185W 21 monitor screen
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
I order these parts from www.digikey.com because they are less than a buck a piece, and arrive next day (shiping here is a flat $8 rate, your location may vary)
Posted on Jul 11, 2011
I have the FPD2185W. Off and on now I get small,
Check to see if there are any magnetic or electrical power supplies located recently moved near the monitor area.
Nov 13, 2009 | Gateway FPD2185W 21 in. LCD Television
No Screen on monitor, GREEN light comes on, blinks once, then off
put a vedio card in your computer then, restart your computer.
Jun 16, 2009 | Gateway FPD2185W 21 in. LCD Television
FPD2185W Gateway monitor
If they dont due anything Contact Monitor Depot Link was below BBB they fixed mine for 99.95 works great Let me know how it turns out
Oct 24, 2008 | Gateway FPD2185W 21 in. LCD Television
Gateway fpd2185w tft lcd monitor repair
Probable failed power supply. If you look at the screen on an angle after your system has finished booting and see faint images, it is the backlight or is associated high voltage power supply that has failed.
If you see no 'shadows' at all, then the main supply has failed.
Either one of these could be a separate supply since many manufacturers buy from specialized companies.
Aug 24, 2008 | Gateway FPD1975W 19" LCD Monitor
My Gateway Computer Screen is faded ,everythink looks like on the screen ...for example- you print something and no paint in the printer and the colors letters.etc. hardly visible ....so my computer screen...
It sounds like the voltages set in the LCD driver color references are dead. Maybe if you open it up it will have a loose voltage divider or bad LCD clock/voltage distribution boss circuit. It can of course be that the transistors on the panel are themselves destroyed, but check the below first:
Set the resolution to the monitor's native resolution (1680x1050), and change the panel's brightness and contrast to try and improve things. If it's not glare, make sure the temperature is okay for operating the monitor and perhaps check the video source (another video card or such.) Did the monitor always have this problem?
May 11, 2008 | Computers & Internet
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
334 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
