Question about Dishwashers
Stale smell on crockery after wash - Dishwashers
  • 38 Answers
Most commonly, this relates to sulfides or other impurities in the water itself, but may also be caused by a buildup of food soil within the washer. Smell a clean glass of water. Does it smell stale also? If no, clean the screens and wash water sump/tank within the machine.
You can also clean the inside of the machine by using a commercial grade dish machine detergent and increasing water temp if possible.
If the water smells stale, consult a local water expert for guidance in resolving
Posted on Aug 19, 2008
6ya staff
SOURCE:
Obnoxious smell from washer
I use "Affresh" every couple of weeks to keep the washer smelling good. Here is the product to order.
Nov 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
Smell of stale water from Avanti compact washer
It may not be draining very well.
I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.
I also add vinegar to most washes but that's due to my teenage son's athletic wear.
Both those things do the trick.
You shoudl probably check the mechanics as well but the above is a stop gap.
Sep 14, 2012 | Avanti W789SA Top Load Washer
My dryer smells like an old wet wash cloth. It has a stale water smell to it and is making my clothes smell like it. I can smell it when i open the door and stand right in front of the dryer opening. the...
There is a very simple way to get rid of unwanted smells. I would suggest use a cup of white vinegar every wash to clean from stale muck and smells inside the machine.
Jul 24, 2017 | Dryers
My dryer really smells and is making my washing smell reall stale
Check the inside for wearing of plastics or dirt accumulated on the TUB. use some vinegar to wash the tub and clearr off using detergent.
if the smell persists you must check inside for dirt accumulation in the drain or the inner tub.
May 16, 2011 | Dryers
Inside smells like stale water
YOU NEED TO RUN A (CLEAN CYCLE) ON THE WASHER.THIS CAN BE DONE WITH A 1/2 CUP OF AUTOMATIC DISHWASHER SOAP AND HOT WASH CYCLE. YOU SHOULD BE ONLY USE 2 TABLESPOONS OF H.E. SOAP IF THE WASHER TO PREVENT THIS
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Apr 26, 2010 | GE WBVH6240F Front Load Washer
Stale water smell
washer is under warrenty so called a repair man
May 18, 2009 | Roper RAS8244LQ Washer
Front loader smells like stale cigarettes during cycle
Make sure that you are using high efficiency (he) detergent. Pour 2 cups of vinegar in the tub and fill the detergent tray with vinegar. Run it on the hottest, longest cycle. You can also use a Front load cleaner such as Afresh, made by Whirpool. I think that Tide makes one too. Vinegar is usually readily available. At the end of washing for the day, leave the door to the washer slightly open so that fresh air can get in and dry it out keeping moldy, milduey smell down. If it mildews, use a rag and bleach water to clean the boot seal. Hope this helps.
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Foul Smell from my GE Adora Washer..!
Having the same problem as everyone else , I make a habit of cleaning the filter once a month. I would like to advise people that if your load is heavy (such as scatter rugs) they will not spin out completely even when the filter is cleaned. No more GE for me!!
Aug 21, 2008 | GE WSXH208A Front Load Washer
My washing machine smells stale! If clothes are left in overnight they go smelly too.YUK!
your drain has lint stuck in it ,when the washers done the spin cycle the lint is still there and starts to smell when its done,remove drain hose and remove lint
Jul 07, 2008 | Hotpoint Washing Machines
Dishwashers Logo
362 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
