Question about Intel D845GVSR Motherboard
To upgrade the bios of intel 845gvsr for sata port
I have installed sata port in pci slote but its doesnot show
hard disk on that port
how can i see it help out
Hi. You not required to upgarde your bios. pls tell me ur operating system and pci sata card chip detail.
Manish Mittal
manishmittal2@gmail.com
Posted on Dec 08, 2009
I have intel 845 series mother board but i dont have the motherboard cd
Posted on Aug 20, 2008
My hard disk is 80GB (IDE) when i try to connect another hard disk 320GB (SATA) the mainboard doesnot detect 320GB SATA hard disk and my pc restart every moment note: MSI 848P NEO-V
Hello samanozy ,
Some older motherboards will not support a too wide HDD whatever the interface.
Another point is to know if you have set the boot priorities in the BIOS . Your machine is maybe attempting to boot from the Sata drive .
Best regards ,
fanaudi .
May 13, 2011 | MSI 848 NEO-V P4/Intel...
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
Intel 865GSA
Looking at the vendors I buy parts from, all the cards I saw offer both SATA and IDE ports. Here's one as an example. You definitely want SATA capability as most newer drives are only being offered as SATA, so you'll have a wider selection to choose from.
Another possibility: start fresh with a new system board. If the onboard IDE controller isn't working properly, this may be a warning sign that other problems follow. You might be better off spending your money on a new mobo that already supports IDE and SATA.
Hope this helps you make up your mind. Thanks for using Fixya!
Feb 20, 2010 | Intel 865G Motherboard
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
Hard disk not shown in BIOS system.....
could be a bad connection , IDE or SATA connector on the board ?, the connector on the drive or the cable itself, how old is the board ?
Jun 13, 2009 | Intel DG31PR Motherboard
Dear Sir I want to upgrade my hard disk to SATA 320 GB or SATA 250 GB. But my Motherboard is Intel Corporation D845GVSR and Bios Version is VA84510A.86A.0030.0402160229 System Bus Speed is 533 MHz Sys
No, don't use a convertor. Please buy a SATA PCI addon card.
like this http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=pci+sata&x=0&y=0
the above card will do alot better job than a converter, if you don't have sata and you don't have room for the card then its best that you buy IDE drive which 250GB or more.
thanks and good luck.
Ekse
May 13, 2009 | Intel D845GVSR Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
845GVSR
u should get a PCI Sata Convertor Card for ur motherboard.
May 20, 2008 | Intel D845GVSR Motherboard
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
Intel D845GVSR Motherboard Logo
387 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
