Question about Ricoh Aficio 1035 Copier
How can i fix this problem ??
My transfer belt produces loud sound how can i fix it ?
  • 3 more comments
  • mariam ies
    mariam ies Aug 24, 2008
    yes i know how to remove the transfer belt to check
  • mariam ies
  • mariam ies
    still can't fix it
    it is still producing sound,what can i do with it ???
  • mariam ies
    when i want to solve this problem i remove the transfer belt and put powder on it ,,it works but for a while and then the sound appears again .. i want a permenant solution please
  • Tim Babcock
    Tim Babcock May 11, 2010
    What kind of noise is it making?
    Scholar:
  • 175 Answers
The bearings on the upper fuser roller are notorious for making noise. Normally they don't cause a problem, they just make a noise like a rock tumbler.
Posted on Jun 29, 2009
Yes i know how to remove the transfer belt to check,,and the sound is like continous trik trak sound
Posted on Aug 22, 2008
  • Ricoh Master
  • 2,794 Answers
Turn the transfer belt by hand to check for any binding or noises. It could also be the fuser rollers causing the noise due to bad bearings since it sits above the transfer belt when it it closed into the machine.
Do you know how to remove the transfer belt to check?
Posted on Aug 19, 2008
  • Tim Babcock
    Tim Babcock Aug 25, 2008
    You shouldn't have to put anything on it to get rid of the noise.
    It should either replaced and/or check the assembly behind it for any obstructions or broken pieces.
SOURCE:
How do i fix error code 452 in Ricoh Afficio MPC2030
Paper transfer unit contact error
The paper transfer unit contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates.
?? Defective paper transfer unit contact sensor
?? Defective paper transfer unit contact motor
1. Check or replace the harness.
2. Replace the image transfer belt unit or paper transfer unit.
3. Replace the HVPS-TTS board.
Jan 29, 2016 | Ricoh Office Equipment & Supplies
When RV is plugged-in a loud humming accures nothing to do with air conditioner. Normal?
A solenoid (magnetic contactor), a motor, or wires can produce chattering sound. I think most likely you hear a solenoid that transfers the RV load from one source to another. A manual transfer switch would be quiet.
Electric alternating current solenoids have laminations that can loosen from each other thru vibration and aging, becoming noisy, and are noramly buzzing when energyzed even when new.
Apr 30, 2015 | Heating & Cooling
How to fix a belt that is making a loud noise on a 1994 Ford Taurus
If it is a loud squeaking sound, the belt is stretched out too far for the tensioning pulley to take up the slack. Check if the belt has grease or oil on it. If it does find the cause, fix the cause and then change the belt...there is no tension adjustment to be made,
Jan 14, 2013 | 1994 Ford Taurus
I have Lifefitness 9500HR, commercial, when belt is running it produces load rubbing sound and when somebody is in it, the sound gets louder. What causing it?
this happen because lack of maintenance schedule, shut down and produce enough friction and loud, and shut down for to protect the electronic systemLUBE Inmediately the deck belt,maybe is time to replace the deck belt. by WORN.
2) LUBE THE rollers bearing too
3) test the motor voltage input, if there are the MOTOR need REPAIR.see my persosnal TIPS.
God bless you
Oct 16, 2012 | Life Fitness 9500HR Next Generation...
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Hi, i am using ibm x3400 M7975 server. its amber light is lit and it produce a loud fan sound after every 30 minutes. it produces teh same sound when u first time switch it on
there is problem with fan assembly .all the fan cage is not properly fix just fix it.
i personally face this type of problem and fixed with the help of ibm engineers they given me diffrent fan assembly. just fix that
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 27, 2010 | IBM x3400 Server
When i plug it in it makes a loud noise and produces smoke. that smells like something is burning
SOUNDS LIKE YOUR BELT IS BURNT OUT, YOU'LL NEED TO TAKE OUT AND REPLACE. Try Sears for this part. An inexpensive part.
Dec 07, 2010 | Vacuums
Horizontal lines down left margin
Sounds like it's a transfer belt and not a drum you are refering too. Each toner cartridge mose likely has a drum built into it. If the lines are only in one color it may be that toner that is bad. But most likely it's the transfer belt, often called an ITU (Image Transfer Unit) or ETB (Electrostatic Transfer Belt). They sometimes get contaminated with dust, oils from fingers, etc... and can't be cleaned, would need to be replaced.
Jan 10, 2008 | Lexmark C510 Laser Printer
Transfer belt errors
I saw this posted somewhere on the internet and it worked for me.
Take out the transfer unit and look at the bottom. One side has visible wires. Open the side panel on that side. Follow the 3 wires to a C shaped sensor held in with a screw. Remove the sensor and blow canned air in the slots on the inside of the C. Put it all back together and hope for the best.
Sep 30, 2007 | Samsung CLP-500 Laser Printer
Ricoh Aficio 1035 Copier Logo
486 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
