Question about Sony Playstation 3 (PS3) Console
PS3 wont turn on
I have my 80 GB from USA and i moved to Korea. here i hooked up the A/V cable to a transformer (voltage difference) and when i plugged in the HDMI cable to the PS3 from the TV, my whole house's lights went out. After I turned lights back on, i tried to turn on my PS3 and the red light doesnt even show anymore. my wii and ps2 work fine. how do i solve this? PLEASE HELP!!
  • 23 Answers
I'm not sure, but it sounds like you may of blown your PS3.
Posted on Sep 14, 2008
Macintosh aoc monitor refresh rate
Europe has different power supply parameters than the USA, Obviously you discovered the voltage difference, hence the transformer, but the USA sends AC voltage at 60 cycles per second while most of Europe is at 50 cycles. You need a converter, not a transformer, if your monitor is capable, you may be able to set it to operate on the different frequency from display settings, or the monitors internal menu
Oct 17, 2012 | Apple Mac Mini Desktop
Input voltage
Yes but you would need to change the power adaptor
Jul 04, 2010 | Iomega HDD External Desktop (32660) 80 GB...
I have a Phillips TV made in Europe, Model 26pf4310/10, It is 220volt, 50Mhz. Can I use a transformer to step up the USA voltage (220) and Mhz to (60)? 2. Is there a card made to convert this TV to USA...
yes you can use a transformer to convert 120 to 220 volt .it must be rated for 110 watts load or more . the 50 hz vs 60 hz (not Mhz) is ok .. if it works on 50 hz then it will work on 60 as well for most things ...here is an excerpt from the service manual on power:
Mains connection
Before connecting the TV to the mains, check that the mains supply voltage corresponds to the voltage
printed on the type plate on the rear panel of the TV. If the mains voltage is different, consult your dealer.
there may be a jumper or switch that allows different voltage operation .. if not the transformer will work ..
... the problem is that it will tune only PAL and SECAM ... the tuner wont tune NTSC or our high def channels .... it will siill work however if you use an external hi def or cable tuner that has direct outpuuts like svideo or composit video or DVI .. (cant use RF) ... it will accept ntsc from dvd players and VCRs .. even a computer can be hooked up ....its resolution is 1280 X 768 so not full hi def but pretty good ... so you cant use the antenna input but everythig else will work ...
here you can find a user manual in PDF form if you need one ....yikes its kinda long URL but good info....
.http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=PL&slg=ENG&sct=LCD_TV_SU&cat=TV_CA&session=20090618144335_66.249.66.170&grp=SOUND_AND_VISION_GR&ctn=26PF4310/10&mid=Link_UserManuals&hlt=Link_UserManuals ...
Apr 12, 2010 | Televison & Video
Xbox 360 to korea
I think your migh only be able to work in Canada, USA or latin america then.
Apr 04, 2010 | Microsoft Xbox 360 Console
I have my 80 gb PS3 hooked up to my STR-DH800. I
You may need to enter the setup menu on the PS3 and enable the decoding for blu-ray discs.
Dec 13, 2009 | Sony STR-DH800
How do i get ps2 games to play on my ps3
The only way how to play PS2 games on PS3 is to have the correct version of the console. Either your Playstation 3 can play PS and PS2 games or it can't, and there's not much to do about it. Most of the PS3 models simply cannot play older titles as they lack the necessary hardware and firmware. However, a few models do have backwards compatibility. The 20 Gb, 60 Gb, and original 80 Gb models all have backwards compatibility, either through hardware or software emulation. The other models lack backwards compatibility, so even knowing how to play PS2 games on PS3 won't help you out much here.
Aug 18, 2009 | Sony PlayStation® 3 (80GB) Console
No audio or visual via AV Cable
turn the power off in the back and then turn hold the power button in on the front then turn it back on in the back and continue to hold the front power button down for 5 seconds and you should here a beep then let go. Then turn it back off then on
Apr 26, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wouldnt turn on
Sounds like it's overheating try moving it to a different location. If it's still under warranty contact Sony
Mar 27, 2009 | Sony PlayStation® 3 (60 GB) Console
Ps3 power issues
Yes you do otherwise you will fry your system.. Thats like plugging an american phone charger into an outlet in spain.. I did it one lol no bueno!
May 22, 2008 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
121 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
