Question about HP Compaq Presario v3000z Notebook
Bluetooth using compaq c702TU
I am not able to turn on my bluetooth in my notebook. There is no option to turn it on just a bluetooth device not found when i right click on the icon on my  system tray. please help.
thanks
    Problem Solver:
  • 8 Answers
Try to Install This:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&product=3540058&dlc=en
Don't forget to rate me on FixYa.
Bye
Posted on Aug 19, 2008
SOURCE:
I want compac pasareo c 702 tu sound drivers
http://www.driversquad.com/driver.php?option=o&prodid=102&cust=download+compaq+sound+driver_AD_www.google.com_compaq+presario+c702tu+sound+drivers&channel=&subid=201_US*DR_o&roia=!iicYvq1BAAKLOkMAAAYOVQAAZT5CAABnCA-A
I hope this helps.
May 03, 2011 | Computers & Internet
I have a HP Compaq nc6320 laptop & the Bluetooth used to work, but hasn't for a while now. On the the logo on the taskbar, instead of it being blue & white, it is blue & red. If I click on it,...
I have had the same problem this might sound bit extreme but it worked after re-installing windows xp (if you have the recorery disks)When laptop starts up hold down "f11"
Sep 26, 2010 | HP Compaq nc6320 Notebook
My bluetooth software is asking for device and say device not found.what can i do?
Follow the step.
1. run the bluetooth driver.
2. asking for device, then you turn on the bluetooth & wait.
3. Your laptop automatically found the device .
4. after finish installation on your phone bluetooth.
5. now search your phone from laptop bluetooth.
Thanks. Hope its helpful. If you face same problem then your bluetootg device is damaged. Thanks again.
Mar 23, 2010 | HP Compaq nx5000 Notebook
Could not found the bluetooth connection or device
Make sure you have every driver for your laptop loaded. Then let's suppose you want to connect your phone to the laptop bluetooth: Turn on the bluetooth in your mobile and make it visible to the other bluetooth device then only your handphone will detect the other bluetooth device and viceversa. Most of the recent notebooks are having bluetooth enabled but in some notebooks we need to turn on the bluetooth by using the buttons which indicated as bluetooth. Once you turn on then get into your computer running windows vista type this following command in the search box or in the run box "ncpa.cpl" it will take you to the network connection window [you can even use control panel option to reach the network options]. In that window where you find the bluetooth connection.Click the icon first and look it on the top of the window where you can see an option "Connect the the bluetooth"click it then you need to add the bluetooth device click add. It will find your hand phone then it will ask the passpharse key you can create one and then your handphone alert you to type the same key that u given in the notebook.Once it matched it will connect automatically. Later type bluetooth in the search option where you will get an option as Bluetooth(Transfer files wizard) . Click it then you receive or send the file via bluetooth between your notebook and handphone. Hope it helped.
Aug 05, 2009 | Lenovo 3000 N100 Notebook
I've a problem in connection between this device and my Compaq Labtop. I'm coding a model based on this hardware but i have a problem in connection to trace a pen moving
Turn on the bluetooth in your mobile and make it visible to the other bluetooth device then only your handphone will detect the other bluetooth device and viceversa. Most of the recent notebooks are having bluetooth enabled but in some notebooks we need to turn on the bluetooth by using the buttons which indicated as bluetooth. Once you turn on then get into your computer running windows vista type this following command in the search box or in the run box "ncpa.cpl" it will take you to the network connection window. In that window where you find the bluetooth connection.Click the icon first and look it on the top of the window where you can see an option "Connect the the bluetooth"click it then you need to add the bluetooth device click add. It will find your hand phone then it will ask the passpharse key you can create one and then your handphone alert you to type the same key that u given in the notebook.Once it matched it will connect automatically. Later type bluetooth in the search option where you will get an option as Bluetooth(Transfer files wizard) . Click it then you receive or send the file via bluetooth between your notebook and handphone.
May 27, 2009 | Interlink ePad E-Signature (VP9801)...
Media device not found
Let me guess, did you downgrade from Vista to XP? Same problem here solved by reinstalling the drivers in a very specific way, too long to go into here, only to have the drivers uninstall themselves less than a week later. Have reinstalled them 8 times always with the same result. I can tell you how to reinstall them, but as to why they uninstall, I am still working on that. Contact me at [email protected] and I will send you the detailed instructions on how to reinstall drivers.
Mar 19, 2009 | HP Compaq Presario C500t Notebook
Compaq Presario C702TU Notebook pc
try find with website compaq...
mayb you can fix it...
choose your model and search using compaq website...
you can found it...
good luck...
Apr 19, 2008 | Computers & Internet
HP Compaq Presario v3000z Notebook Logo
163 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
