Question about Cameras
Lens jammed after dropping it - Cameras
    Genius:
  • 2,985 Answers
Throw camera away buy the next one.
Tell more about the camera
Posted on Aug 19, 2008
Sony a290 For second time lens locking pins are jammed down and won't locate to lock lens in place. (Previously had to have new mechanism fitted which cost as much as camera)
change the particular section of locking pins.
Or first apply one drop of cleaning oil like WD40.This will release the Jammed condition.
Oct 06, 2013 | Sony Cameras
Says lens error restart camera yet my lens will not close
Hi, your lens has probably been damaged , usuallly by dropping or bumping , or sand or some other particle may be jamming it. Try using a piece of photo film ( exposed negative) to search for anything that may be stuck in the lens where it telescopes out. Another "fix" is to firmly bang the corner of the camera case into the palm of your hand quickly after pushing the power button.This may loosen the jam
Oct 30, 2009 | Canon PowerShot A540 Digital Camera
Jammed lerns
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Kodak EasyShare C743 Digital Camera
Dropped camera jammed zoom lens on nikon 28-85 lens
You have impact damage, the gears in the lens are out of alignment.
www.cameradr.com
he is a friend of mine who can fix this for you.
Jan 08, 2009 | Nikon Coolpix S210 Digital Camera
Jammed digital zoom lens
For whatever reason, the lens has failed. This can be caused by many things: the lens motor has failed or is stuck, the gears involved in driving the lens have jammed, or, as pointed out previously, the lens itself, a series of tubes which fit into one another has become stuck. You can try GENTLY pressing down on the lens when you first power the camera to see if you can free up the stuck lens. If that doesn't work, I'm afraid you are going to have to get the camera serviced.
The clicking sound you're hearing is the lens trying to move itself. Unfortunately, it's probably not going to be fixed by pushing on the lens. You are going to have to get the camera serviced. Sorry!
Oct 27, 2008 | Polaroid Cameras
Lens error
same happened with mine. some people pushed it back in or used a thin driver to jam in in between the side with the bigger gap.
try it while you press the on button.
Mine is still jammed so I'm going to either get it replaced but try disassembling it first.
Aug 28, 2008 | Nikon Coolpix 5200 Digital Camera
Lens retracts with difficulty
1. Do you have a camera case?
2. Or do you not?
The dust fibers from the case might have gotten into the cracks of the lens causing it to jam. So everytime it retracts, it jams. That's what i'm guessing. My old camera got jammed from sand grains on the beach.
- Take a thin strip of paper, and insert it in the cracks of the lens and circle around the lens and find any dust or anything. The paper slip should come out a bit dirty if that's the issue.
- Gently nudge the lens around, until you hear a click. The lens might have jerked into another position from the inside.
Aug 08, 2008 | Canon PowerShot SD600 Digital Camera
JAMMED LENS
The track inside of the lens and maybe other damage has been done. This is something that you cannot do yourself, unless you are trained, have access to the parts, and experience in camera servicing.
You should send the camera to the manufacture authorized service rep for an estimate.
Apr 14, 2008 | Samsung Digimax S600 Digital Camera
Cannon Power shot SD630 Lens Problem
Sorry to here that you can send it to a repair company like me for repair. cost about $120.00 plus shipping to fix.
Feb 26, 2008 | Kodak Easyshare M753 Digital Camera
DMC-FX8
If the lens is jammed in the out position you can try holding the camera firmly and tapping/hitting it against your hand with the camera on. The lens should then retract. If this doesn't work or if you are afraid of dropping it (do it on your bed, that way it doesn't hit the floor if you _do_ drop it), you can drop it on a wood/firm surface from an inch or so up and it should retract the lens. This solution ONLY WORKS IF THE LENS IS JAMMED.
Sep 30, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Cameras Logo
413 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
