Question about Amana Microwave Ovens
My amana ace208 convection oven the transformer smokes when asked for power
  • Anonymous Mar 25, 2014
    how do I change degreeon amana from 450 degrees to 400
  • Amana Master
  • 9,086 Answers
The transformer has failed.
You can order one here if you think it might be economical to repair.
Posted on Aug 19, 2008
My Panasonic microwave oven'S digital pad is not showing power when the power switch in on , why ?\
There is a transformer which powers the front panel. Normally attached to the front panel bord. If the transformer is faulty the such problems can occur.
If you wish to get some more details about microwave oven repair then check the below added link http://electro-medical.blogspot.com/
Jul 06, 2016 | Panasonic NN-T888S Convection/Microwave...
Microwave quit working, has no power, the outlet has power
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 '';
Jul 24, 2011 | Amana AMV1154B 1000 Watts Convection /...
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
C5 error on amana dq22hs
A CS error means oven senses to much current or not enough. The problem could be a burnt wire on the door switch, or mag themals. It could also be a ploblem with one of the HV compents. You should have a tech check it out due the the dangerous HV system.
May 01, 2009 | Amana ACE208 Convection/Microwave Oven
Amana converction express
hi my name is mark, try this link http://www.managemyhome.com/mmh/products/ManualSearch.action hope this helps. if you happy with answer please leave a rating.
Dec 28, 2008 | Amana AMC6158B 1000 Watts Convection /...
Burning smell
This could also be a failing high voltage transformer or transformer.
While one should never leave a running microwave unattended, you should especially follow this rule for this microwave until the smell goes away or the unit develops another problem.
If it gets worse, please reply back.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 29, 2008 | Amana AMV1162 Microwave Oven
Amana ACE208 doesn't work with a message 'door'
The door latch receiver has a spring action lever (inside) that is made out of plastic and cracks or wears through. You need to remove the cover and remove the two screws holding the door latch receiver. Now you can switch the top and bottom piviot switchs, putting the top one lower and the lower one on top..make sense? you"ll understand when you see it.
Feb 26, 2008 | Amana ACE208 Convection/Microwave Oven
Volume control
no there is no way to adjust the alert they come already factory set.good luck
Apr 16, 2007 | Amana ACE208 Convection/Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
