Hi.
E2 F3 means Oven temperature is too high (Cook mode).
The first part to be tested is the temp sensor. The sensor is located inside oven cavity and it is tested using a multimeter set on Ohms to read impedance at sensor contacts.At room temperature, sensor resistance should be 1K to 1.1K. If not,
replace the sensor. If the sensor checks okay, check for a short to in element wiring (element stays always on). If element and sensor are OK replace the control.
Regards.
Ginko
