Question about Kitchen Ranges
Bosch HMG 8480 combination oven/microwave, blows fuses within half a second of microwave being activated but oven working fine
3 Suggested Answers
  • 136 Answers
SOURCE: our Whirlpool 27" Built-in Combination
This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q-- My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section
Q - I burnt something in my microwave and now it is dead...help!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
also look for this electric wiring chart given in this link below just click on the link
http://www.applianceaid.com/image/microflowchart.JPG
thanks.
Posted on Oct 13, 2008
SOURCE: Bosch combination oven/microwave HMG 8220GB start button doesn't work
I have a question about the machine how do you set the time I have one but can't set the time so it won't do anything
Posted on Mar 30, 2015
I need a manual for the Bosch hmg 2210
don't know what a bosch hmg 2210 is. I don't own one. What is your problem with it?
why not just check online. might be easier than expecting us to find it for you.
Aug 19, 2014 | Microwave Ovens
My Whirlpool microwave MT6120XEB-0 keeps blowing the fuse. Inststalled new fuse and display and timer works. Cooking blows new fuse. It turns on, makes grinding sound and blows a new fuse within a second...
You almost certainly have a shorted high voltage capacitor.
See the safety warnings and help information here.
Chances are you will have to remove the oven from the wall to replace it.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 26, 2013 | Microwave Ovens
This is a door switch problem, one of the door switches has malfunctioned preventing the microwave oven from running.
May 14, 2012 | Bosch Microwave Ovens
My Bosch microwave (built in HMB5050 has stopped heating all of a sudden. Everything else appears to work fine but it does not heat. What is the problem?
I have the same issue, plus mine shuts down after 30 seconds. There are a few other similar issues on here, with solutions including unplugging it for 10 seconds, replacing a fuse, and replacing half the internals. Please post your fix if you find one!
Jul 28, 2011 | Bosch 500 HMB5050 Microwave Oven
My microwave oven stopped working. No lights, clocks etc. I have checked the outlet and it is fine, power available. Is there a fuse somewhere inside the microwave?
There is a main fuse in the microwave oven, "white body with silver ends" located near the high voltage capacitor. Unplug unit take top off and allow 30 seconds to dis-charge. Keep in mind the door switch becomes defective and often blows the fuse.
Mar 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Error message E8 is shown in the clock display
Error Code: E8 Cause: Control Board Example: Remains in display; oven unusable Corrective Action: Replace control board
Apr 12, 2010 | Bosch HMT8625GB Microwave Oven
My ge over the range spacemaker microwave keeps blowing fuses after a few seconds cook time. This is my second unit within a year and a half with the same problem. Would not recommend this product.
Buy a Microwave Oven after checking it out on http://www.cnet.com .They do a wonderful job rating different products. Check them out and type the product name you are looking for in the search box if not already listed.
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave blowing house fuse, but not right away. Sometimes not, sometimes within 15 seconds, sometimes longer. Any idea what the problem and how to fix? Thanks
PLEASE DO NOT USE OR TOUCH when plugged in. Remove Fuse & UNPLUG IT. The ONLY reason a Fuse "Blows" is due to an Active, to Earth fault. This "Could" place the "Mains" voltage on the "Case" of the Unit, if touched while plugged in it could KILL YOU. Please call a registered professional, to attend to this. It may be in the Unit?, it may be in the wiring?
Feb 10, 2010 | Microwave Ovens
Microwave combination oven failureHME9750GB/03 FD8106 (/555350)
APPLIANCE HAS INTERNAL 8 AMP SAFETY FUSE IF THIS HAS BLOWN IT WILL NEED MAJOR REPAIRS AND POSSIBLY COSTLY THIS FUSE ONLY BLOWS IF FAULTS EXIST WITH HIGH VOLTAGE SIDE OF APPLIANCE SO NO NOVICE SHOULD ATTEMPT A REPAIR.
Jan 18, 2010 | Bosch HME9760 Microwave Oven
Bosch HBC84K520B Combination Microwave Oven
If you google search bosch gourmet the second item down titled "bosch household appliances" you can download a manual from there
Jun 27, 2009 | Bosch HMB402 Microwave Oven
Kitchen Ranges Logo
336 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
