Question about Sharper Image SI655SIL Portable DVD Player
Dvd player I have a 2003 sharper image dvd player and i THINK the model number is AR-900. it's small and portable. i'm trying to set it up with my television and i only have one chord for it- the power chord. i need to get a chord to connect it to my tv but i have no idea what kind (i no longer have the manual). also- i tried plugging it in, just to make sure the power would at least turn on- and it doesn't. my parents gave this to me when i moved because they never used it- and now i'm stuck. please help!! thanks, emily
    Genius:
  • Sharper Image Master
  • 1,550 Answers
Go to radio shack maybe they got the cable you need to connect it,its a 3.5 mm to standard rca´s.Good luck
Posted on Aug 19, 2008
How do i conect a dvd player to a Model UE32C5100QW
This will depend on the output type(s) of your DVD player.
If the outputs on the rear of the DVD player are Yellow (vodeo), Red and White (left and right audio) then you will use standard Composite RCA cables running to the A/V inputs of matching colors on the rear of your TV.
If the DVD outputs are Red, Blue, Green (video) and Red and White (audio) then you will use Component RCA cables leading to the appropriate inputs of matching color on the rear of your television.
Both of these methods will produce a standard definition image and you made need to adjust your television to get the image to display properly. You will also need to use your remote to switch to the appropriate input you used.
In some cases newer DVD players may have an HDMI output and you can use that to connect to one of the HDMI inputs on your TV. However, this will still produce a standard definition image although the DVD player or your TV may "upscale" the image to try and produce a sharper and cleaner image.
RCA cables, both composite and component, are available at retail stores such as Walmart, Best Buy or other electronics retailers. You can also find them online via Amazon, Newegg or other electronics retailers. Most shouldn't cost much and probably considerably less than a quality HDMI cable.
Feb 28, 2015 | Televison & Video
Player will not start. it has power but the movie does not start. model number sd-p1600
This is not a TV problem? The sd-p1600 is a portable DVD player. Are you trying to connect it to your TV? Or is you Portable DVD Player not playing?
Jan 06, 2011 | Toshiba 42H81 42" Rear Projection...
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
Key locked
on the right side you will see 2 green lights for charger and ac input, and a little slide that locks and unlocks it
Jul 18, 2008 | Sharper Image SI655SIL Portable DVD Player
My kid's Spongebob TV SB315 model is all screwed up!! I try to hook up a dvd to it and can't watch anything!
I believe that what you are watching are the responses of the portable DVD player on screen menu. How about just trying to get the tv to work for now, then try the DVD again?...accordianman
Apr 11, 2007 | Emerson SpongeBob SquarePants TV
Problems with Image on Polaroid DVD player
try moving thew screen to its down potsion because the switch that reverses the picture is not working. theres a small switch inside the piviot point inside so that when you move down the screen all the wat flat away from the player the screen is supose to reverse so it can be veiwed. Good Luck
May 23, 2006 | Polaroid PDM-0723 Portable DVD Player
Sharper Image SI655SIL Portable DVD Player Logo
122 people viewed this question
Top Sharper Image Televison & Video Experts
Demonic-2011
Demonic-2011
Keith Peterson
Keith Peterson
Are you a Sharper Image Televison and Video Expert? Answer questions, earn points and help others
