Dell 3100cn gives message load front tray even though paper tray is full
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
If this unit is a bit older, than it's possible that the sensor switch is stuck
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
I cannot figure out where to load legal sized paper into our Dell 3130cn printer? Can anyone assist me?
The handfeed tray normally opens from the front by pulling down on it. You can load any type of paper in this tray. Good luck.
Dec 12, 2012 | Dell 3100cn Laser Printer
Dell 3115 manual feed doesn't work
If this printer is a few years old on the load paper tray there is 2 grey rubber rings they get a flat spot on them. replace and no paper problem till the next time they wear out
May 25, 2012 | Dell 3100cn Laser Printer
Whenever a print job is sent to my dell 3100cn laser printer, ?Load tray 1? appears in the small window of the printer. I loaded the tray several times but it doesn?t work. Please guide me through the...
You sent a paper size different of the requested by the printer. Just load the requested size or delete the spool.
Some PDF downloaded from internet has A4 or 8,5x11", maybe is requesting one of this sizes.
If you can not delete this message, delete the spool using the printer manual in the control panel of the printer.
Dec 11, 2010 | Dell 3100cn Laser Printer
My dell 3100cn makes a horrible grinding noise and eventually stops and says paper jam on tray 1 even though I am using the MPF
sound problem with the gear set, if your plastec gear where worn out and jam, it can occured error you need to trace what gear is that and need replacement.
Apr 09, 2010 | Dell 3100cn Laser Printer
I have a Dell 3100cn that will not print as it continually states Load Tray Letter. The tray is loaded, I have rebooted multiple times any other thoughts?
The paper sensor is likely malfunctioning or there is a paper jam causing the printer to "think" that there is no paper in it.
Oct 15, 2009 | Dell 3100cn Laser Printer
The printer message says: load paper tray and it is already load
Something to try, The paper (roller) may be slipping on the paper giving false reading of Load paper tray. UNPLUG THE PRINTER FROM MAINS and CLEAN the (roller) as best you can with quick drying solution, Tape cleaner or Similar. Good luck Bob.
Mar 18, 2009 | Dell 3100cn Laser Printer
Paper won't pick up from the paper tray. I keep getting a load error message or paper tray message no matter how I load the paper. I get the codes "A4" and "024-964" Thanks
Check your printer for paper size and type settings. Ensure they are set to letter and plain1. Also check the program you are printing from (Word, wordperfect, etc) and ensure the paper size is correct there as well.
Feb 25, 2009 | Dell 3100cn Laser Printer
Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
Jan 08, 2008 | Dell 3100cn Laser Printer
Dell 3100cn
check the tray for a special piece of plastic that, when rotated or adjusted some other way, confirms the tray is holding what paper size and orientation. I know HP used this on older lasers.
Jun 04, 2007 | Dell 3100cn Laser Printer
187 people viewed this question
k24674
jasbo
jasbo
