Question about Lexmark Office Equipment & Supplies
MY SCANNER WILL LET ME SCAN MULITPAL COPIES BUT YOU CAN NOT READ THEM WHEN YOUR DONE??
  • jellybean80 Aug 19, 2008
    HAVE TRIED TO SAVE AS A JPEG, AND PDF. AM SCANNING AT 300DI AS WELL. YOU CAN SEE WHAT IT IS SUPPOSED TO BE BUT IMAGE IS NOT READABLE
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Sounds like a settings issue..when you select how to save them, this would be an option.
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
  • Patrique Davenporte Aug 19, 2008
    image is not readable in print or on monitor?
My canoscan LIDE 100 won't make multi copies of my drawings!
The scanner itself does not make copies. You scan and then reprint as many times as you need with a printer. Make sure your image settings are suitable for your printer eg save as a jpeg or pdf file and then reprint that. If you are trying to make your system do a function it is not capable of, you need to change the way you are doing it.
Mar 02, 2017 | Canon CanoScan LiDE 90 Flatbed Scanner
Can any one help to find product that uses validated keypad code entry that could "unlock" the device and take copies and lock Once that is done, for canon 3300 copiers.
The Canon 9080C is purely an input device and cannot 'take' copies, however it can scan any A3/A4 document which can be printed or emailed. By printing you get the copy. Technically it is possible to control the software/Computer through Software password.
S. Mohan
Aug 29, 2010 | Canon DR-9080C Path-Through Scanner
Can i make copies of a paper
Hello.
If you have a HP DeskJet 6840 then you won't be able to make copies since it doesn't have a built-in scanner. You can buy a scanner separately, scan the document using the scanner and then print it using the HP.
Apr 05, 2010 | HP DeskJet 6840 InkJet Printer
My kodak esp3 will not scan it prints and copies.
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
May 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Cant scan it just copies a portion of the page i wanted scaned
hi
if your lexmark scanner drivers are proeprly installed in your computer then u can see your scanner wizar in
settigns - control panel -scanner and camera wizard.
then open lexmark scanner and simply follow the procedure.
thats it sir.
Apr 21, 2009 | Lexmark X2500 All-In-One Printer
Can't read what is scanned
What you need to do is get some cleaning solvent from a Computer Store and clean the class. If this does not correct the problem then try uninstalling and reinstalling the drivers. It sounds like your screen may just be dirty. If you can print it and then scan it that is very perculiar. Try this and let us know if that fixes the problem.
Dec 30, 2008 | HP Officejet 5610 All-In-One InkJet...
The scanner copies three photos as one
Assuming you're using the Epson Scan software, select Home or Professional mode and click Preview. When the preview image appears, draw a marquee around each of the three photos. (Note that as you draw each marquee the number beneath the little image of a marquee - the white square with the dotted line around it - increases.) After drawing your marquees, click the All button, then click Scan. The scanner should make three separate passes in succession, producing three separate images.
Nov 24, 2008 | Epson Perfection V200 Flatbed Scanner
Scanning multiple copies
The trick is to put the scanner in PROFESSIONAL MODE !!!!! Select that option in the top right corner of the Epson Scan application when it first opens up.
http://files.support.epson.com/htmldocs/gt25__/gt25__ug/projs_1.htm
Dec 21, 2007 | Epson Stylus CX4200 All-In-One InkJet...
Control panel is stuck on copy
Hi, try this, remove any and all software for your scanner and THEN re-install the LATEST drivers, and software for your device. Once you have done so set all your defaults and hopefully you will find it is all working again.
Mar 30, 2007 | Microtek ScanMaker s400
13 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
