Question about Rockford Fosgate Punch 800a2 Car Audio Amplifier
Ampilifers my power wire has juice but the amp is not coming on
    Problem Solver:
  • 4 Answers
Check the fuse in the amp.
If the fuse is good, make sure your remote wire (blue) is connected to the remote wire from your deck.
Is your ground connected?
Posted on Aug 19, 2008
How can i hook up a car stereo in the garage without using a car battery, and get the same juice as far as wattage and power???
Wire a 12 volt AC adapter to it. Connect the power to the positive wire, & the ground to the negative wire. If it's a low power unit a 1 amp adapter will work. If it's a high powered unit you might need a 12 volt 5-10 amp adapter designed for monitors, TVs, monitors, & some laptops. Beware some laptop AC adapters can be 16-36 volts. Make sure you use a 12 volt one, & know which wire is positive, or you'll burn it out.
Jul 08, 2015 | Cars & Trucks
The power light comes on then it give out
jl audio 12w7 with jl audio 1000.1
get a high volt capacitor 8 or more fared a breaker fuse 100amp .Best bet is to have an another battery hook up in back of truck for this kinda set up cause this amp really pulls alot of juice
May 20, 2010 | Jl Audio 1000/1 Car Audio Amplifier
I just got a used karaoke laser disc player ...no manual.....can it be hooked straight to speakers or does it need to go through a receiver?
Hello, the karaoke laser disc player, does it comes along with a self ampilifer if it does, check for the serial ribbon cable that is used to interconnect the disc player to the self ampilifer and connect the speakers to the output port of the ampilifer and not directly to the laser disc player.
If it does not come with a self ampilifer, then you can connect the speakers direct to the laser disc player.
With the following above it will work effectively for you to enjoy the laser disc player...
Apr 28, 2010 | Audio Players & Recorders
I have a problem with the wireing on a 1971 nova,i have no juice to the fuse box,no lights,dash lights ect. and no juice to the ignition switch,it is all dead
more than likely the power wire coming from the starter is bad, they have inline fusable links built into the power wires coming from the starter, make sure these are all hooked up and the links are not burnt. A service manual/haynes, etc will give you schematics and link locations
Mar 31, 2010 | Chevrolet Nova Cars & Trucks
Amp turns on for split second, with the clip light on channel two flashing as well, and each time i do this the fuse on the power lead blows. Tapco Juice 1400 amp, thank you.
if youre amp is new return it sounds like you either have a faulty hook up or youre amp needs fixin...check youre wires espacialy youre ground not touching power...
Feb 24, 2010 | Bob Mackie Tapco Juice Stereo Power...
Power amp wont power up
Check the fuses-should be a pair of 30 amps on the side. use a paper clip and jump power from the power+ to the remote+ and see if that lights it up-if it does than your remote lead isnt giving it juice-
Apr 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
No power with amp
make sure the remote wire has juice when the head unit is on then check ground
Nov 25, 2008 | Pioneer GM-7100M Car Audio Amplifier
I bought a 2400 watt punch 801s amp that has two power out and two ground outs i've hooked up only one power and one ground and the amp comes on but as soon as i touch the speacker wire to it it hits one...
Check the gauge on the wiring. For that size amp you would need to use 0 AWG wire for the power, the speaker wire is just signal wire so you want to use regular speaker wire. (I have 12 AWG setup for speaker wires) What the two power ports (Neg and Pos) do is increase the amount of flow. Two power wires to distribute the flow of the current so you don't burn up your wires if your pumping too much juice. I started off with this exact amp running a single 8 AWG and split it into two and it burned up and blew a fuse after a couple of huge bass hits. So proper setup would be....
BAT(+)---FUSE HOLDER(60AMP+)---DISTRIBUTION BOX(30AMP+)====AMP
GND(-)===AMP
-- would be 1 wire pref 0 AWG splitting into more 0-4 AWG
== would be the 2 wires (Yes two ground points in separate locations would be better)
Thus finalizing you have a proper setup.
Be careful you don't burn out your alternator, this bad boy can cause some serious problems with a lower amp alternator. Let me know how it works out.
Aug 15, 2008 | Rockford Fosgate Car Audio & Video
Ampilifer removal
unclip cover and let it hang down on the hindge on the passenger side
Jun 18, 2008 | 1993 Lincoln Mark VIII
Car Audio & Video Logo
98 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
