Afficio 450 camera lense alignment
Hi can any1 der can help me how to align the camera lense of afficio 450... bcuz i cleane it up and den wen i return it back ....the print has no copy at all and tried to align it but i can get the exact alignment sometime my alignment is good but the copy is just like der is a mirror at the top of wat i der any oder way dat i can align it with exact alignment... tenk in advance....sometimes i encounter error code SC 101 ... wat it means...
  • thraser
    thraser Aug 21, 2008
    nope i have no manual to calibrate the scanner datz what im looking for...i olridy try to align it in many ways but i cant get the exact alignmen some times da output is clear but the margin is not diz align sometime it has no copy just ol white ... the onli problem is that the alignment of camera and itz sensor? after the camera to align it... tenkz in advance
  • Tim Babcock
    Tim Babcock May 11, 2010
    I'm going to put this in my que to look it up. Usually on digital copiers it is unesessary to align them because they calibrate themselves plus becuase they use a CCD to record the image, there are fewer mechanical parts to them. Messing with the optics isn't necessary and if they are messed with it can cause a lot of problems. It it is an analog copier thats another story.
  • 2,794 Answers
You need a manual to calibrate the scanner do you have one?
There are some holes in the scanner that need to be calibrated with a tiny screwdriver. The manual teslls you the correct settings.
Did yiou remove the cable?
Posted on Aug 19, 2008
Parts and consumable of afficio 450
Sep 07, 2009 | Ricoh Aficio 450 Copier
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Afficio 450 is der a sensor in toner supply
Do you know how to calibrate the toner/developer sensor?
Jan 26, 2009 | Ricoh Aficio 450 Copier
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Afficio 450 copy faded in some area...
If the image is good in parts, but light in others it is most often toner build up on the laser exposure glass which can be easily -but also VERY CAREFULLYremoved. If you lift the green handle for the toner bottle, you should see a narrow piece of glass protruding just underneath. You can grasp it with you fingers and slide it out for cleaning. Sometimes these have been removed (or broken) so they are not there. If the machine is also a printer, you should see much improvement (if this was the cause). If regular copying is still light in areas, then you may want to remove the copier glass - 2 screws on left scale, and 3 screws on rear scale (POWER OFF ON MACHINE), remove glass and clean with glass cleaner, then slide scanner to the left and clean the mirrors.
Hope this helps.
Jan 17, 2009 | Ricoh Aficio 450 Copier
Afficio 450e gray copy or lighter copy
Look into replacing the developer in your copier. It has to be replaced every 125,000 cycles.
Jan 14, 2009 | Office Equipment & Supplies
Afficio 450 sc 322
1st laser synchronization error.  This should be looked at by a Ricoh technician to see what needs to be replaced.
Sep 11, 2008 | Office Equipment & Supplies
Afficio 450
Goto to Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Fuser..?? afficio 450
The fuser probably will not help. I think you probably will need a PCU, and a service call.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
75 people viewed this question
