Question about LG KU990 Viewty
LG KU990 - Memory Full
I am trying to receive an MMS. Phone says Memory Full. When I try and go into Memory Manager and into Common Handset memory - It is 100% full - I try to reset it. Looks like it does something. But when I go back into the Common Handset memory it is again 100%.
How do I delete common Memory things such as Default Sounds and Default images? There are some Sounds I will never use and images I definitely will Not use.
Any idea how I can delete these?
Thanks
  • 1 more comment
  • vincewest Aug 22, 2008
    Thanks I will do that.
  • lauren722 Feb 16, 2009
    is there anyway i could do this myself? i don't think any of teh technicians here would know how to do this withput deleting some of my files that i need on my phone ... i don't want to loose certain videos,images, songs and files....
    thanks
  • lauren722 Feb 23, 2009
    same problem here - if i select delete common memory, the phone asks if i want to delete licenses too ?
    what will happe if i say okay ?
    please help- desperate to fix this!!
    Brigadier General:
  • 7,752 Answers
The phone;s firmware need to be reflash on the phone, so take it to a mobile center to have it done.
Posted on Aug 21, 2008
SOURCE:
How do i reset my handset common memory? i tried to reset it did not worked.. it seems my handset memory was full even if i tried to erase it.. can you help me?
Have you tried: 3845#*990# to get into the factory menu, from there You can do a reset. BE CAREFUL NOT TO CHANGE ANYTHING ELSE!
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 25, 2011 | LG KU990 Viewty
When I try to open a game I get a message saying 'Memory Full'. When I enter memory manager to clear space,only the common memory is full. Can I clear this memory? When I try it asks if I want to clear the...
try moving pictures or applications to your Micro SD card to free up your common memory. Also free up your messages this also caused same problems
Sep 09, 2010 | LG GT505 Cell Phone
My handset memory always full.. if clear also cant.. i cannot send or receive any mms
i got the same problem....did u get any solution to how to clear phone memory???
May 17, 2010 | LG KF310 Cellular Phone
I also can't receive mms on my LG Ku990
main menu,settings,phone settings,connectivity,access points then delete from there
Oct 20, 2009 | LG KU990 Viewty
Handset memory full
check your phone memory it might be full try to save your photos in memory card and remove unwanted data from your phone memory
Sep 13, 2009 | LG KC910 Renoir Cell Phone
Why does my lg reniour say memory full when i try and change my wallpaper?
hi, if you go to phone settings>memory manager>handset common memory you will probably find it is full or nearly full, most of that being used by 'others'. You won't be able to edit photo's, use them as wallpaper, send or recieve mms or e-mails and probably other stuff too while your memory is full.
You can try to 'clear all' here and see if that works, but if not as with my two, try going to browser settings and pressing reset settings. it took ages on mine and i thought it had frozen but when it eventually finished I had 69% free on both phones and everything worked fine again.
Make sure you are using a memory cad too and that the primary storage is set to external....just in case!
Aug 13, 2009 | LG KC910 Renoir Cell Phone
LG Renoir Memory Problem
plse reset you phone code 0000or1234 try it
Jul 20, 2009 | LG KC910 Renoir Cell Phone
My LG KU990 can not see my micro sd card even thought it's in the phonr
when you go into my files on he phone scroll right to the bottom and it should say external memory or memory card.
i hope this was help...
Dec 01, 2008 | LG KU990 Viewty
Cant get downloaded games onto mu LG KU990
copy then to a folder named other and try now
Nov 24, 2008 | LG KU990 Viewty
LG Secret
hey! i also had the same problem. i could only send files through bluetooth but couldn't receive them but recently i found out it's becuase my handset common memory was full. so if you delete some files u have on ur handset memory..u may be able to receive files again. this worked for me but im not sure if you have the same problem as i did. i thought that the files received on bluetooth would go to my mircoSD memory chip thingy but apparently it didnt. SOOOO if ur able to send files through bluetooth it should mean that the bluetooth connection itself isn't the problem....i think. it's just ur handset common memory that is full. u can go check the memory space by going to Setting ->Memory manager ->Hanset common memory.  Hopefully this helps!
Nov 04, 2008 | LG Secret ? KF750 Cellular Phone
LG KU990 Viewty Logo
757 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
