XFX NVIDIA GeForce 8600 Graphics Card Logo
Posted on Jun 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I install nvidia geforce 8400gs. I want to use the multiple display so that i can view video through my s-video but never work.I bought another card with HDMI out still the same problem. I thought may be i have problem with my driver or nview I need help .Thank u
Anonymous
Level 3:
  • Master 961 Answers
  • Posted on Jun 10, 2011
Anonymous
Master
Level 3:
Answers
961
Questions
Helped
273652
Points
3003
The model number would be helpful in determining exactly which card you have but, s-video should certainly work and they also make an adaptor that converts s-video to component video if that's something that you want. You will have to, if you haven't already, get into "control panel" and then get into "personalization". There you should see your two monitors. Here you can adjust your resoulution. You will also have to check in "device manager", click on the box(on right) next to "monitors", it should show your 2 monitors. Right click on each, one at a time, and in the dropdownlist you should see "disable" if you see "enable" click on that and exit. If you see any warnings, !, ?, or a yellow triangle, click on thta and follow proceedure. You may also want to click on the box next to "display adaptors" and check for warnings, right click on and make sure it' also says "disable" in list with both monitors connected.
21helpful
Download GF8400GS 512M DDR3 32B(TC)CRT DVI HDMI
Hello the driver can be downloaded here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
By selecting geforce
Geforce 8 series
Select 8400GS
And your windows system.
Then the driver can be downloaded.
You have to reboot the pc, when the driver install is done.
Good luck
4helpful
I want galaxy graphic card drivers
You do not need specific 'Galaxy' drivers. You need the right NVIDIA drivers.
Go to http://www.nvidia.com/Download/index.aspx?lang=en-us
and type in on the page: Geforce, Geforce 8 Series, GeForce 8400GS,
Your used Operating System, Your used/wanted language and download.
1helpful
About geforce 8400gs gen2 tc1g 64bit ddr2, it is okey to run in window7 32bit. i already install and run but only read 512mb.
There should be no reason why this card won't work with Windows 7 32bit, it could be as simple as your Graphics drivers are out of date. I recommend downloading the latest Windows 7 drivers for your card at the Nvidia website.
Just remember graphics RAM and SDRAM are two completely different things so they don't add up.
As far as I know the 8400GS is a 256MB card.
Installed GEForce NVidia 8400GS graphic card but no video output. Onboard and other video cards will work. The 8400GS will work in other desktops correctly. Any help would be graet!
Assuming that you have installed the drivers for your new board, go into Control Panel, select Device manager and Display Adapters.
Dissable the onboard adapter and enable the NVidia card.
Video card driver problems
If possible try to install mother board CD drives to rectify this problem or search for motherboard related video drives from net to download and install
Video card malfunction
Explain in further detaill
Please
ALso malfunctions can be from overheating
We have install the nvidiageforce8400 driver during installation showing scatterd display on the lcd what i can do for that
That can not be the right driver for your video card. I suggest you roll back to its previous driver. Look for the latest version of the driver for your video card.
1helpful
3answers
Problems with 8400GS graphics card
First, you need to be sure you have installed the correct drivers for the card that corresponds to your OS.
Second, you need to go into the control panel (assuming you are running Windows of course) and tell the computer you now have a new graphics card installed and to use it instead of the default one detected when the OS was installed.
Reattach the monitor to the GeForce card and reboot. All should be OK.
Clone
l'ecran de mon ordinateur compaq ne s'allume pas juste ya une petite fenetre volrnte qui me dis pas de signale
Top XFX Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
