Contributor
- Posted on Aug 19, 2008
Re: I Have a Hp Deskjet F380 ALL-In-ONE...
How do I download and install the software?
To download the software, do the following:
Click here to go to the Software and Drivers page for your product.
Click your operating system.
In the Driver section, click the appropriate software driver.
Follow the instructions on the page that appears to download and install the software.
How do I install from the CD?
Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install.
The recommended install is designed to work for most users.
Use the custom install only if you have one of the following reasons:
Low hard disk space on the computer.
You do not want the additional software.
Errors occur during the recommended installation.
NOTE:
If errors occur during the recommended install, fix them before doing a custom install.
Recommended install
Complete the following instructions to install the software:
CAUTION:
Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long.
NOTE:
Choose unblock or accept on all firewall messages or the install will fail.
Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically.
NOTE:
The User Account Control screen might display. Click Continue .
Click Install on the Thank you for purchasing from HP! screen.
Click Next on the Welcome to the Install Wizard... screen.
Click Next on the Do Not Block HP Install Wizard Processes screen.
Select Yes or No on the Automatically Check For Updates screen and then click Next .
Choose the Yes (recommended) option to check for updates through an Internet connection.
Choose the No option if you do not want to check for updates.
Select Recommended on the Installation Options screen, and then click Next .
Follow the instructions on the screen that displays to finish installing the software.
Custom install
CAUTION:
NOTE:
Select unblock or accept on all firewall messages or the install will fail.
NOTE:
Select Custom on the Installation Options screen, and then click Next .
Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space.
NOTE:
You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
