The fuse keeps blowing every time i put new one in it
  • 10,594 Answers
If there is short circuit in power supply, fuse will blow itself to disconnect the circuit just to avoid fire or further damage in unit. Please check power supply of your unit.
Posted on Aug 19, 2008
Efi Fuse Keeps Blowing
It could be a short in the wiring, or a shorted injector possibly.
To check for a bad injector, pull off all injector connectors, put new fuse in, and turn key to on. Does fuse blow? If so, maybe a short in the wiring, possibly a problem in the ecu. If fuse is still good, put the injector connectors back on one at a time and watch the fuse. If one injector connector causes the fuse to blow, that could be a shorted injector. Good luck, don't know what else to check after that.
Dec 30, 2012 | 2002 Lexus Gs 430
Mazda 626 ac fuse keeps blowing
Try unplugging the compressor then put in a new fuse. If the fuse does not blow, the problem may be the clutch on the compressor.
Jul 29, 2012 | 1997 Mazda 626
01 kia rio keeps blowing the injector fuse every time i put it in first and take off how do i fix it
You may have a shortted injector. Pull all the injector connections off, put a new fuse in. If it still blows the fuse, you must have a short in the injector drive circuit from the ignition switch to the injectors. I don't know what all is in the circuit, but you may have a resistor pack before the current reaches the injectors
If the fuse did not blow, then one at a time, reconnect the injectors. You are looking for a shorted injector that blows the fuse. If the first connection blew the fuse, disconnect that one, put in a new fuse, and start with a different injector connector. You may find one that blows the fuse, meaning it is shorted, and needs replacing.
Good luck.
Apr 08, 2012 | 2001 Kia Rio
Keeps blowing the radio , interior light and clock fuse (10 amps)
Disconnect all three items from the car's wiring harness. Put in new fuse and connect them one at a time. When the fuse blows you know which is bad and either replace/fix it or live without it.
May 15, 2011 | Honda Civic Cars & Trucks
My tail lights are not working, it keeps blowing my fuse.
1.Unplug your taillights at the sockets and the front running lights from sockets.
2. put in new fuse after unplugging taillights.
3 turn on taillights if fuse blows then the wiring is grounding out somewhere between the switch, fuse panel, and rear and or front parking lights.
4.If fuse does not blow then plug in one socket at a time keep rechecking fuse. when the fuse blows after plugging in a certain socket suspect that one to be bad and replace.
Sep 15, 2010 | 2005 Infiniti G35
Why does my fuse keep blowing for my tail lights in my 96 plymouth breeze ?Every time I put fuse in it cut the lights on the fuse blows?
The fuse keeps blowing out because there is a short circuit. Check the tailight sockets for corosion. Is there a tow package wiring installed?
Jul 26, 2009 | 1996 Plymouth Breeze
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Fuse #12 for 2000 lincoln towncar keeps blowing
fuses are a safety device. they are made to blower when to much load is drawn over them. some component on the circuit is shorting out. if possible unplug all the items on that circuit. put in a new fuse, then reconnect component one at a time until the fuse blows again. a process of elimantion. it may take some time, but it will be expensive to take it to a dealership.
Jan 10, 2009 | 2005 Lincoln Town Car
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
79 people viewed this question
 Grubhead
Grubhead
