Help i did uninstall my cd rom how can i fix it, or where can i go to repair it
  • 68 Answers
Your cd rom is damage or working??
Posted on Aug 19, 2008
Will not recognize cd's but plays and records dvd fine
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device also scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
May 15, 2011 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
Dont matter what cd i put in the cd rom none of them work and when i go into my computer the cd rom is not reconized
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 09, 2011 | Dell Computers & Internet
I got a hp cd-writer cd12 series multiread cd-r/rw on a really messed up windows millenium edition computer yet it reads as cd-rom only drive i'm tryin to no success and will keep tryin to fix that so i...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
or
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
Dec 26, 2010 | HP CD-Writer Cd4re CD-RW Burner
I can not get my Cd Rom to read a disk
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 26, 2010 | Acer (91.47A37.001) CD-ROM Drive
My dvd rom is not working, how do i fix ti
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
hope this helps
Nov 24, 2010 | HP Pavilion dv2000 Series Laptop Full...
My CD Drive is no longer working it says code 39. I also tried my external DVD drive it says code 39 as well. How do I fix this?
hope this helps
Oct 21, 2010 | Compaq (120192-B21) CD-ROM Drive
Cd rom
First use the following steps:
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
Mar 10, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
The CD-ROM, Run but too slow.
CD ROM Drives
This site could help ya in need of the drivers .
Hope this fixes the problems you are having .
This could help ya in the way of doing this your self at this site.
Have a great evening.
Dec 02, 2007 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
