Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag mav5200aww points in timer stuke (hot)
Can i just replace the timer
  • 1 more comment
  • seumasb51 Sep 13, 2008
    timer points are fused in some possisions disrupting operation sequence I PLAIN ON REPLACING TIMER PUT WONDER IF I SHOULD BE LOOKING DEEPER
  • maryandjackm Oct 12, 2008
    my washer just fills up with hot water no matter which temp i put it on cleaned the screens and also when it gets to the rinse cycle it does nothing so i have to put it back to the original starting place and fill it and put it back to spin to spin it out
  • john gagnon
    john gagnon May 11, 2010
    for what problem
  • 943 Answers
Hi thanks for the question i would have your timer rebuilt from a appliance timer re builder much cheaper thanks the appliance doc
Posted on Sep 15, 2008
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
Timer on Maytag dryer will not move.
Sounds like timer motor is bad. Most likely will have to replace timer.
Nov 06, 2017 | Dryers
Washer over flows wont agitate on all load sizes will spin out water runs both hot and cold water on all settings from tap cold to hot timer doe not seem to move
we have a pressure switch problem...replace pressure switch,,,i dont understand what a cold to hot timer is,,,i assume you me water temperture switch...
Sep 02, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have a maytag MSD2556AEA refrigearator and the coil freezes up. I've replaced the the defrost timer and the heater and it still freezes up.
While the suspected components have been replaced it is also important that the defrost timer works to move forward and switch on the heater. Also the connections to the defrost timer and heater must be checked., Secondly the thermostat must be checked or should be kept lower than the present point or to normal.
The compressor MUST CUT OFF from the switch on the defrost timer and put the heater to work. if not check the timer and wiring.
Jul 19, 2011 | Maytag Refrigerators
Maytag Model A511 Cold water will not fill for wash or rinse cycles. Water is on, hoses are straight, and filters are clean. Water valve checks out OK (110V across terminals on both solenoids, slight...
Hi and welcome to FixYa, I am Kelly. Your testing of the solenoid was good. My question is this... when the timer stops do you still get the magnetic attraction? If I interpet this correctly; the answer is no. So we are dealing with a power problem. Power comes from the timer straight to the COLD solenoid. (Blue wire)
http://www.appliancepartspros.com/sect/i/e/j/iejjijajjf.gif (wiring diagram)
Power comes in to the TIMER from the lid switch on the red wire of terminal 12. It is supposed to be then routed to Yellow wire terminal 3 and the internal contacts of the timer (buss 14) connect power to the BLUE wire 5B. If your not getting power at the timer 5B / Blue wire lid closed the problem is inside the timer. Just make sure the timer connections discussed above are correct ON the timer.
Maytag PN 2.5639 timer NEW price is around $147.00 for factoryoriginal Used Avg $35.00. Your choice if you need a timer.
2-5639 +Maytag (Net image search)
Thanks for choosing FixYa,
Kelly
Jul 19, 2011 | Maytag Washing Machines
My maytag gas dryer timer does not turn, does not get hot, does not shut off unless I shut it, why?
HI. This will occur when the timer mechanism(timer motor assembly), becomes fused, or the motor itself has failed. The timer mech is the main initiator of all the selected cycles. If the timer is unable to rotate properly, the unit will not heat or stop as well. Replacing this defective timer module will correct this issue.
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Timer won't stop
If the timer is still running thru stop points and continues running thru you timer is definitely bad.YOU EASY PURCASE ON AT YOUR LOCAL MAYTAG DEALER OR ONLINE. Glad to be of service.
Jan 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MAV6000 Top Load Washer Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
