I need to restore my acerpower series back to the factory settings is this possiable
    Brigadier General:
  • 6,966 Answers
Yes it is possible. Two ways:
  • use the recovery CD that came with the AcerPower when new;
  • use a n OEM or a borrowed Windows installer and use the serial number stenciled/printed on the sticker either underneath or at the back of the unit. You would need to re-install some if not all of the appropriate drivers. This would be a better approach since the unit's hard disk could be re-partitioned, reformatted and a clean fresh install could be done.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
How to reset to factory default
Restore the factory-set defaults
CAUTION:Restoring the factory-set defaults returns all of the product and network settings to the
factory defaults. The procedure then automatically restarts the product.
1.
On the product control panel, press (X451 Series) or touch (X551 Series) the Setup
button.
2.Scroll to and press or touch the Tools menu button.
3.Scroll to and press or touch the Restore Factory Defaults button, and then touch the OK button.
The product automatically restarts
Jul 22, 2014 | HP Officejet Pro X451dn Printer
How to restore to factory settings
Go to the ASUS WEB site for instructions -
ASUS Notebook Restore to Factory Settings
http://en.kioskea.net/faq/4162-restore-an-asus-netbook-to-factory-settings
Sep 01, 2012 | ASUS F3F Notebook
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 13, 2011 | HP LaserJet CP1515n Printer
I want to restore my computer back to factory settings , " out of the box "
you can easily restore your system if you purchase the laptop as pre-loaded operating system. restart your system and press F11. It'll start restoring your laptop as factory settings.
Note : plz take your back up before restoring...
thanks & regards
Anas K A
Jul 08, 2011 | Toshiba Satellite L500 Series Notebook
How to reset zebra p4t ribbon cartridge?
Below are the command sequences that can be applied to default the parameters referenced above:
Examples:
! U1 do "device.restore_defaults" "bluetooth"
! U1 do "device.restore_defaults" "ip"
! U1 do "device.restore_defaults" "wlan"
! U1 do "device.restore_defaults" "power"
! U1 do "device.restore_defaults" "display"
The zpl parameters can be restored to their factory defaults on the P4T series, RW series and QLPlus series by deleting the ZPL_CFG.CFG file. This binary file contains the zpl settings and will be recreated automatically when restarting the printer. The newly created file will contain the binary equivelant of the factory zpl default settings.
The ZQ500, QLn series and the iMZ allows the ^JUF and ^JUN command to be sent to restore parameters to their factory default condition.
Example: ^XA^JUF^XZ^XA^JUN^XZ^XA^JUS^XZ
Please note that the iMZ uses line print mode by default. The command ! U1 setvar "device.languages" command may need to be adjusted to se the iMZ back to ZPL if necessary.
! U1 setvar "device.languages" "zpl"
Zebra Technologies Restoring Factory default settings with Mobile Printers CCTV Networking Technical Support
Feb 04, 2011 | Zebra 05555bk110d 4.33 X98' Tt Wax/resin...
Need to restore to factory settings
start > all programs > accessories > system tools > system restore, restore it to the first point, and though this will erase all your files prior to, it will roll back your computer back to the original settings... also going to computer info, you can reset the settings to the default...
Feb 23, 2010 | Toshiba Satellite 1800-S204 Notebook
Trying to restore back to factory what can i
When you purchased the computer, you should have received a set of "System Restore" CD-ROMs. Use them.
If you have lost them, telephone HP/COMPAQ, and order a replacement set of "System Restore" CD-ROMs. The cost could be $20 for the set, and $20 for courier-shipping. When the disks arrive, use them.
P.S. Backup all your music/files/bookmarks/contacts before doing the "factory" reset.
Nov 13, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Acerpowerfh keeps turning on and off rebooting why?
it does sound like a boot virus problem. you need to boot into system restore. to boot from the restore partition you need to switch on your pc and repeatedly press either F10, F11, Alt+F10, or Alt+F11. you do this until you see the system restore starts. you will be able to fix windows, or you can do a desturctive restore and restore your pc back to factory settings, but you'll loose your photos and anything saved on the hard drive.
Apr 22, 2009 | Racer AcerPower FH PC Desktop
Format/restore computer to factory settings
Press F11 at system startup to get to the NEC recovery menu. From there, you can restore your factory settings. However, a "destructive" recovery will wipe the hard drive, including your personal files. Best to back those up first before performing the recovery.
Hope this helps - remember to rate :)
Oct 02, 2008 | HP 419320-001 - HP Pavilion dv4000 Series...
My friend gave me his old acerpower s series computer with Acer 91.E4259.U81 Motherboard.problem is i cannot get any sound i have been in the bios,the acer website for driver upgrades and even fitted a...
Hi, i have a acerpower s series computer and mine had no sound either. What i did is when i first turn it on the acer logo appeers with a blue background and then it will ask to to press ctrl alt esc to enter setup. Do that. When in setup go to the option to restore to default settings and then save and exit (i think you press escape and then yes). This mght work because theres a setting that disables the onboard sound and restoring defaults will enable this. Do the oposite of this http://www.acersupport.com/desktop/articles/pse_sound_dp10499.html
or go to the acerpower sn support articles if you still having trouble http://www.acersupport.com/desktop/articles/psn_articles.html
Also upgrading to windows xp might fix this aswell. Hope this helps :)
Jul 07, 2008 | Acer Computers & Internet
Computers & Internet Logo
David Payne
David Payne
