Question about Omano Science & Laboratory
My Omano microscope worked for a couple of months, but suddenly stopped working - it will not turn on. No, it has never been bumped or dropped. The bulb and fuse both seem to be in good condition - taken out and adjusted multiple times for connection issue, but it still will not turn on. Serial # 0716495 Joseph McBee Portland, OR
4 Suggested Answers
SOURCE: digital blue time lapse
Depending on the model of your USB, (1.1 or 2.0) it may or may not time out. With a 2.0 speed USB it will not typically tome out until about 30 hours of very high activity use. A 1.1, on the other hand can get to do that a lot. If your USB is a 2.0 get a computer expert to check that it is not malfunctioning. If it is a 1.1, I would suggest getting a USB upgrade.
Posted on Apr 28, 2007
Dave Duff
  • 30 Answers
SOURCE: Microscopes
Well then ?
It sounds like you do have a pre-tension problem, and if the fine focus is slowly turning as the stage desends, that is where your problem is. If you could tell me make and model, fixing it should be no problem.
Regards.....Dave
Posted on Mar 10, 2008
alphacheese
  • 68 Answers
SOURCE: my microscope won't focus
If your stage is still in its correct orientation then make sure your objective lenses are screwed in tight as well as the eye piece being secured correctly. Try using different objectives (don't go too high or you may damage your lenses if you ram it into your specimen) and using the fine and course focus. If the you still cant focus using different objectives it's quite possible that your mirrors or lenses inside the microscope have been knocked loose. I would then recommend only having it repaired by a certified microscope technician. If it is still under warranty take it back to the store of purchase or send it back to the manufacturer.
Posted on Jan 07, 2010
Edu-science 4 way normal microscope with viewer, projection and drawing device
Hi, Carole normally I would have re-categorized this question since it got logged in under the motorcycle section, but I thought what the heck I will give it a shot and it's for a girl/women, I found the catalog but no manual it's a kids toy and judging from the reviews, not a good one in fact even if you had a manual it may not function the way you would like, you may want to try returning it for a better brand if that is at all possible I recommend the "Omano OM117L" for $80 For more information about your issue please click on the links below. Good luck and have nice a day. Amazon com Customer Reviews Edu Science Microscope Set 150X 450X 900X Toys...
The Best Kids Microscopes of 2016 Top Ten Reviews
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 14, 2016 | Science & Laboratory
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/chris_e1fb7ef6a5bdb086
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
Why is my nespresso Citizmilk D120 milk frother not spinning? Milk does froth up.
I have the same problem. it was working beautifully but then stopped for no reason to turn. If I hold the whiskers sometimes they turn and other times not. Weird! it happened some months ago and then I tried a couple of months ago and it suddenly worked. Now the same problem has re-occured. Wonder which part needs to be replaced - does anyone know?
Mar 03, 2012 | Nespresso Citizmilk D120
Only work on reverse
After seeing a suggestion for a similar post I got a can of compressed air from a computer store to clear the sensors in the paper feed. It needed a long blast but it started working again. Tip. My instructions say, every 6 months, put a few drops of olive oil on a sheet and feed thru; try doing every couple of months to stop the sensors getting covered in dust
Dec 09, 2011 | Fellowes Office Equipment & Supplies
My mio navman m300 will not turn on, its 2 months old and was working fine then suddenly would not turn on, its has not been dropped at all. any ideas??
hi,
Plug it and leave it on charge for at least 4-8h. Try both car charger and USB cable, it could be that the issue is the cable and not the battery
Nov 22, 2010 | Mio Moov M300 GPS for Europe 35" screen...
Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Mar 19, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
Touch screen not working?
well wen you dropped it did the ink move luiek the colours where were wrong for example the white was pink etc.. if this has happened ,and it is common in touch screen phones, the phone is no longer good you can still keep it if you want but the problems will get worse n worse until its just gone
Aug 09, 2009 | LG Dare VX9700 Cell Phone
I have a 1997 Plymouth Neon. The car runs great. The lights all come on but the gauges suddenly stopped working. It was fine yesterday..could it be a fuse?
Try a couple of good thumps with fist above dash (don't laugh) where cluster gauges are, and see if it comes back on, or may when you hit a bump. I had a 95 that did it all the time until I fixed it. If a bump or thump gets it back on, let me know, I'll give you details on fixing.
Feb 22, 2009 | 1996 Plymouth Neon
My windscreen wipers stopped working in heavy rain. I stopped the car turned the car on and off a couple of times and they started working again this has happened twice in the last six months
I have a Range Rover 2006 and suddenly under heavy rain the wipers atrat going very fast and quit working, I change the speed and work again but after a minute the wipers quit. And I can not find the problem . Somebody can help me?
Aug 26, 2008 | Land Rover Range Rover Cars & Trucks
Microscopes
sir,
Diffrent company having their own system for microscope arm balacing.
Tell me which one microscope you have.
Auxillary arm or microscpe body sloly come down ward.
tell me problem is consult with which part..
INDRAVIJAY
Jan 02, 2008 | Tasco 750 Monocular Microscope
Science & Laboratory Logo
381 people viewed this question
Top Omano Science & Laboratory Experts
S J Parkin
S J Parkin
ray gallant
Tom Chichester
Are you an Omano Science and Laboratory Expert? Answer questions, earn points and help others
