Businse how are you my brother work life
  • 3,051 Answers
Please tell us what your problem is that u are experiencing
Posted on Aug 19, 2008
Reset Drum life MFC 9440CN
Not sure if this Brothers is the same but normally open front were you install drum and toner, machine on depress, menu button or clear button, display will show 1 or 2 to tell
you to reset drum count.. hope this works
Mar 04, 2016 | Brother MFC Office Equipment & Supplies
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
How do I reset my drum life once I have inserted a new drum in my brother MFC-7440N printer?
Open front cover; hit CLEAR button; hit PLUS (up) button. Close cover. Done.
May 19, 2010 | Brother MFC-7440N Laser Printer
How do you reset the fuser count of a Brother HL4070CDW?
If reset parts is life not available after OK > Machine Info > Reset Parts Life (if it only shows "Parts Life", then do this:
Press GO and UP arrow at SAME TIME > Reset parts life
Scroll up or down to choose which part to reset
Press OK and confirm
Apr 14, 2010 | Brother HL-4070CDW Printer
How do you reset fuser life on a brother HL 4040cn
Press the Go and 'Up' buttons at the same time in the ready status.
The "Reset Parts Life" will appear on the LCD. Select the applicable periodical replacement part by pressing the 'Up' or 'Down' button and press the 'OK' button.
Mar 25, 2010 | Brother HL-4040CN Laser Printer
Toner Life has ended
Did you pull the plastic tape on the cartridge?
Feb 11, 2010 | Brother IntelliFax-2820 Laser Fax
TONER LIFE END APPEARS ON LCD
try opening front door, press "options" then "start" then "1" and "0". if screen shows accepted, you're good to go. close front cover.
hth,
razors
Feb 06, 2009 | Brother IntelliFax-2820 Laser Fax
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
