Question about Philips Magnavox DVD/VCR Dual Player
Recording TV shows
The manual says it has no tuner ?
Does this mean I wont be able to record tv shows as with all my other VCRs. What exactly is an external tuner. The only tuner I have in my stereo rack system.
  • rcby1 Aug 19, 2008
    Why should I pay you to assist me with a problem with your product
  • 8,596 Answers
Since it doesn't have a tuner, it will not be able to store channels - it will only record the channel that your cable or sat box is on currently
Posted on Sep 05, 2008
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
Jan 22, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
I have a new digital tv in which i use an antenna to watch it. i hooked up the vcr to it but i cant get it to record the tv show i want recorded.
Your VCR most likely does not have a digital TV tuner. Therefore you must supply a digital TV input signal so you can record it. Unless your TV has a composite video output, you would need another box, namely a digital TV tuner/converter which would connect to the VCR's input. Select the channel to record on the tuner/converter and select on the VCR the input where the tuner is connected.
Aug 14, 2010 | Sony SLV-N71 VCR
I cant record TV
Proper setting is required. This time i don't know what connection you have, in case you use RF IN, fine tune your VCR's Tuner to the desired channel you wish to record. If you connect via A/V IN, select proper input on your VCR. Good Luck
Mar 01, 2010 | Televison & Video
Connect VCR without tuner to record from television
If it has a scart, you can get a scart lead to connect it to your TV. You would need to set the VCR to the Scart socket, IE: AV1 etc.. to record. You wouldn't be able to change channel on the TV, to watch another channel while recording though. If you had a set-top box, you could connect that up to the scart of the video then record, while you watched another channel on your TV.
Feb 06, 2010 | Televison & Video
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Is it possible to record one show, while watching another ??
You need to put a cable splitter on the cable. One side goes to the TV. The other side goes to the recorder. The output of the recorder goes to one of the alternate inputs on the TV. Set the recorder for whatever channel you want to record using its internal tuner. Use the TV tuner to watch a show live. Later, set the TV input to whatever you connected the recorder output to and watch your recording. You will probably need to do this to see the recorder menu to set up the recording.
Mar 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Vcr recorda blank when digital tv is put on standby.
this is because you are recording a direct connection (what is on the screen is recorded) that is an option with some equipment.. unfortunately this means if there is nothing on the screen well you get nothing..
You need to record from the machines own built in tuner dont use direct record.. a vcr/pvr/dvdr after all remember is like a tv without a screen that can record it has its own channels to do this
Sep 30, 2008 | Televison & Video
Taping shows on a jvc vcr.
Well from memory... you have to Plug in the Antenna to the Video, then from Video to TV, then ya Tune in the "Tuner" section of the Unit.. that outputs on ya TV, then you can simply press the record button(s).. also there is the option of Timer Recording... There was also a TV/VCR switch that had to be toggled on some models... But ya really need a manual I believe the manual is at the below link... www.sharefx.com/archive2.asp?offset=174400
Sep 04, 2007 | JVC HR-S9500 S-VHS VCR
Philips Magnavox DVD/VCR Dual Player Logo
291 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
