Question about Panasonic Microwave Ovens
Microwave oven comes on when the door is open, we then put what ever we are heating up and turn the oven on. After it times out and goes off the microwave oven turns on again when we open the door to remove the food and goes off when the door closes.
  • Panasonic Master
  • 9,086 Answers
It sounds like either a bad door switch or door switch mount, or a sticking relay on the control panel.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can order Panasonic parts here.
Otherwise, I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 19, 2008
Sharp microwave has power but does not work and door wont open
Door catch is possibly broken. Consult a qualified Sharp microwave agent.
Jul 29, 2014 | Sharp Microwave Ovens
Microwave won't stop running
there's a ghost in your microwave, call ghost buster. Seriously, the problem is the control panel. (((((the microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. That's more than 30 wall outlets combined.
Replacing electronic parts in a microwave oven can be extremely dangerous.))))))) tank you
Samsung Model SMH1816S XAC Parts
Mar 30, 2014 | Samsung Microwave Ovens
Jenn-air micro convection - cooling fan comes on when door is opened, then goes off, intermintent problem
I have seen where one of the door switches becomes intermittent causing the symptoms you are describing, tough to nail down considering there are more than one door switches.
Jun 16, 2012 | Jenn-Air JMV9169B Convection/Microwave...
We have had this microwave for 7 years. Not had any problems until about six months ago when the volume went way down when you push the buttons and timer, but still heated. Then all of a suddon it does...
Remove the cabinet ... check the door safety interlock switches for proper operation. Most of the time, no heat problems can be traced to the oven thinking the door is open. These switches tell the oven if it is open or closed. If they are faulty ... well ... the oven thinks the door is open and will not turn on the heat.
Make sense?
Thanks for your question today.
Feb 06, 2011 | Whirlpool MH1150XMQ Microwave Oven
When we start it does not heat up the food.
If it doesn't make any loud noise when it turns on check the micro switchs on the door
one is not operating and is putting the microwave in the safe mode. It thinks the door is open.
at 6 bucks each change them all. just use the right ones at the 3 different locations.they come out of. No power and do one at a time and remove the micro holder from the microwave it's easyer to work on. Take note to the McDs microwave behind me....
Dec 03, 2010 | Sharp R-303CW Convection / Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
249 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
