Question about Samsung SGH-D500 Cellular Phone
Sim lock do i just type that into sim lock code area??
  • skeeda Aug 24, 2008
    thank you!!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Hi there, you can take the sim card out and switch the phone on, then enter the code. If this don't work, you will have to take it to a repair center.
Posted on Aug 19, 2008
SOURCE:
Nokia c1-02 sim lock restriction code
this restriction code dos'nt workt to my phone Nokiac1-02 IMEI357887046246384 SIM LOCK RESTRICTION CIDE TYPE RM-643 CODE 059G5L7 can anyone help me ?
Jul 13, 2012 | Nokia Cell Phones
Tip
Unlock codes for Samsung Sgh J700i
<span>1- Power on phone, type : *#7465625#<br />you will identify which code is active , which is inactive. <br /><br />2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone you must see " insert sim" not "invalid sim.." <br /><br />3- Type : *2767*3855# <br />your phone should restart after 1 min,<br />now, and before it restarts, push your sim card in, without removing battery. <br /><br />4- Your phone should work and accept the sim card ,, but if you chek locks you will find that your phone is still locked <br /><br />5- Now type : *7465685*638*00000000*00000000#<br />your UNLOCK CODE is 00000000 now , Enjoy <br /><br />6- Now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :<br /><br />* Disables CP lock : #7465625*27*00000000#<br />* Disables Network lock : #7465625*638*00000000#<br />* Disables SIM lock : #7465625*746*00000000#<br />* Disables SP lock : #7465625*77*00000000#<br />* Disables Subset lock : #7465625*782*00000000#</span>
on Dec 25, 2010 | Cell Phones
Tip
How to Unblock Network lock of SAMSUNG SGH-J700
SAMSUNG SGH-J700 UNLOCKING:
1- Power on pone ,, type : *#7465625#
2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on pone ,, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your pone should restart after 1 min ,,
now ,, and before it restart , push your sim card ,,without removing battery
4- your pone should work and accept the sim card ,, but if you check locks you will find that your pone is still Locked
5- now type : *7465685*638*00000000*00000000#
6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,Here details :
on Jan 21, 2010 | Cell Phones
Sim card puk code n. 8264084361
*#7465625# = Check the phone lock status
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7,
it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then
the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
It may not work in all phones, but with standard its working ;)
Feb 14, 2012 | Cell Phones
I forget my sim lock
Hi,when a cell phone is displaying Sim lock.. Two things you willneed to put under consideration.
! The sim card being blocked and it's asking for a Puk number..
! The cell phone being locked and asking for unlock code for the cell phone
When a sim card is being locked,it will ask for a Puk number whch means that you have exceeded the pin number typing it in more than three times.
To get the Puk code to unlock your phone,you will have to contact service provider which is specific for each mobile number.
Puk code does not affect the phone your using,but it affects the Sim card and it unable you to make out going calls. And you will not have access to thing on your Sim card.
To get your Puk code for you Sim card,you can contact service provider located in your area for help.
You can go to any of your service provider outlet stores around your area.Or you can contact them through customer care line..Am sure you know their phone number to contact them.
You can not get a Puk code to unlock your phone from another source except through your service provider service..
While the phone unlock, issues like this involves Unlocking your cell phone...
When you click on wrong pins, and you forget your pin number, the phone will get to a lock mode..
Trying to unlock it manually will not be possible at that time,because your cell phone will be unacceptable..
At this point in time, you will need to unlock the phone..
There are two methods in unlocking the cell phone..
!. Going to a local cell phone repair store around your area..They will help you unlock it..But it will cost you some money to unlock..
!.Also Through the internet. There are some links on the internet..Allyou will need to do is to give your phones IME..number, make and the model of the cell phone...
Below are some links you can use to unlock the cell phone..
http://www.unlocker.com.au/
http://www.mrunlock.com/
www.askstudent.com/hacking/how-to-unlock-a-cell-phone-for-free-and-get-unlock-codes/
Hope it helped..
Jul 11, 2011 | Samsung B3410 Cell Phone
I just unlocked a blackberry 8100 from t mobile to use on the att network and the t mobile sim still works with my phone however when I put the att sim card into the blackberry I get a message on the phone...
It hasn't been unlocked, try again and follow these instructions:
Model : T-mobile BlackBerry Models
1 – On the Home screen, click the Tools icon. The Options screen appears.
2 – In the tools screen, select the Settings icon.
3 – Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 – Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 – Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 – Input the Network Unlock code
7 – Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 – While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 – Choose “Advanced Options”.
3 – Select “Sim Card”
4 – There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 – Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 – Input the SIM Unlock code
7 – Press in the trackball in once
Your phone is unlocked
Jun 25, 2010 | RIM BlackBerry Pearl 8100
How can ii unlock a blackberry.?!
How To Enter the Unlock Codes on a BlackBerry Cell Phone
422851199_3d16b31e6c_o.pngModel : All BlackBerry Models (except T-mobile)
1 – Using the menu go to Settings Menu -> SIM card press select.
2 – While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 – You should now see the five locking categories listed.
4 – While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 – Release the shift key.
6 – You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 – Enter the code
8 – Enter Return/Enter
9 – The device should then be unlocked
To Unlock:
while typing )
Apr 10, 2010 | Cell Phones
Blackberry pearl wont except sim card
1 - Using the menu go to Settings Menu -> SIM card press select.
2 - While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
1 - On the Home screen, click the Tools icon. The Options screen appears.
2 - In the tools screen, select the Settings icon.
3 - Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 - Type ‘mepd’ to display the first five levels of SIM locking.
5 - Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 - Input the Network Unlock code
7 - Press ENTER and reboot handheld.
To Unlock:
1 - While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 - Choose “Advanced Options”.
3 - Select “Sim Card”
4 - There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 - Type m e p p 2 to display the dialog box asking for the unlock code
6 - Input the SIM Unlock code
7 - Press in the trackball in once
May 05, 2009 | RIM BlackBerry Pearl 8100
How to unlock a blackberry
BlackBerry Pearl 8100 Can be done without a sim card inserted To Unlock:
while typing )
Apr 28, 2009 | HTC TyTN Smartphone
Unlock blacberry pearl 8100
hi there :-)
try this i havn't done this but my friend does now he uses any sim on his pearl.
Pearl instructions - Can be done without a sim card inserted
To Unlock:
1. While on the home screen, click the "blackberry key" on keyboard, then select "options".
2. Choose "Advanced Options".
3. Select "Sim Card"
4. Type m e p p 2 to display the dialog box asking for the unlock code
( you will not see text appear on screen while typing )
5. Input the SIM Unlock code
6. Press in the trackball in once
Finish :-)
peace!
Dec 09, 2007 | Nokia 1100
Samsung SGH-D500 Cellular Phone Logo
101 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
