Question about Intertherm Heating & Cooling
I have Intertherm Model MGH-075AAC, the thermostat is on off but the blower keeps running
  • 3 Answers
SOURCE: Blower on my Intertherm Model mgba keeps cycling
It could likely be the fan control switch. Open up the cabinet, and you'll see a metal box, roughly 7x9x2" inside, with the blower switch located on the top edge of it. There are usually two screws holding the lid on. Remove the two screws and the lid, and you'll see a couple of eye-shaped items side by side with 2-3 blue or orange wires running to them, each. They might have numbers on them such as 6263360 or 6263370. These are the limit switch and control switch, respectively. If your fan keeps cycling on and off, try replacing the control switch (6263370). The new part number for these switches are 626336 (limit) and 626337 (control). The control switch is also one of the cheapest (less than $10) places to start.
Posted on Oct 29, 2009
  • 89 Answers
SOURCE: Intertherm MGH-056ABFC-91 won't kick on. Just
There is probably more than one limit switch. I'll have to get a wiring diagram of this unit. See if you can follow the wires from the wires from the limit switch and see if they go to another limit switch. Also you can put a jumper wire on the red wire and white wire on the unit outside and see if ti comes on.
Posted on Nov 03, 2009
  • 10 Answers
SOURCE: Where are the furnace filters in my older furnace?
On these of Furnaces the filters mount on the door. Remove the door you will notice grill on front. There should be a track on the back of the front door to slide filters down. Should take 2 filters.
Posted on Dec 06, 2009
Testimonial: "drifterray really helped. way to go apprentices!"
heatman101
  • 43501 Answers
SOURCE: I need the schematic for
Probably not going to find that anywhere....what do you need?? I can probably walk ya through it..they are pretty simple...
heatman101
Posted on May 10, 2011
  • 387 Answers
SOURCE: no voltage to thermostat inside
Check the breaker or fuse's then check power supply to the transformer you shuld get 24 volts out of it..
Posted on Aug 05, 2011
Looking for Intertherm MGH-075-ABWN-05 gas valve Model 36c67 type 177
WHITE-RODGERS Type 36C67 - Emerson
www.emersonclimate.com/Documents/White-Rodgers/instruction.../0037-5838.pdf
Type 36C67 complete gas control combines into a single compact package the functions of 3-position Gas ****, pressure regulator, 100% shut-off automatio pilot, main operator and Natural-LP Gas Selector. Termostat Circuit Current (24 V Model):. 0.23 Amps. Pilot Gas Outlet: Located at outlet end of the valve. Type of Gas:.
Need refurbished gas valve & tube - mobilehomerepair.com
https://www.mobilehomerepair.com > ... > Nordyne Service & Repair Feb 9, 2014 - The gas valve model is 36C67 Type177 part# is 6243700 ... Two are a electric oil radiator type & the other two are electric grid type. ... guys that you had to rebuild for me hoping it would solve my Intertherm model MGH-055-ABW36C67 gas furnace not heating up hot enough but did not resolve the problem.
36C67-175 - Hvac Controls - Amazon.com
https://www.amazon.com/Unknown-36C67-175/dp/B003WZWGDE Rating: 4.3 - ‎4 reviews
Product description. Robertshaw, Coleman, Evcon 24V, 1/2" x 1/2" inlet/Straight outlet, Dual Standing Pilot, Step Opening, Mobile Home, Gas Valve Replacement w/Two 1/2" Side Outlets & Reducer Bushing (1/2" x 3/8") ...Missing: intertherm
Apr 07, 2018 | Intertherm Heating & Cooling
I have a Intertherm furnace model# MGH-065-ABRN-05...The target burner needs to be replaced. I type in my model # and it isn't reconized. Is this a good number. Thank You
I don't think that is a good model #. Here is a link to their site and the furnace models there have a totally different type of #.
http://intertherm.net/Products/Furnaces/GasFurnaces.aspx
If you really need the burner, Id call Intertherm and then they can tell you what data plate you should be looking at.
http://intertherm.net/DealerServiceLocator.aspx
Jan 02, 2018 | Intertherm Heating & Cooling
I wonder if you have a picture of where the therm couple is inserted next to pilot for a intertherm mgh 055 furnace
try going to YOUTUBE and insert (intertherm mgh 055 furnace) in the search window for illuminating videos
Dec 22, 2017 | Intertherm Heating & Cooling
I have a Intertherm model MGH-075-ABWN-05 and the A/C stopped working. someelectrical problem i'm guess.neither the blower fan nor the outside unit are running at all
Check the drain line for a float switch. Remove float and check for water. Do not leave float out, you must clear the drain. Good Luck
May 10, 2017 | Intertherm Heating & Cooling
Got Intertherm Model # MGH-055AB.. It lights for ap 10 seconds goes out then goes out... Over and over again does not stay lit long enough for the blower to start running?? ANY IDEAS HOW TO FIX IT ?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If the s3 comes on then you have an issue with the unit and i would get a professional to help.
Air Conditioning Boca Raton
Apr 10, 2015 | Intertherm Heating & Cooling
Looking for a gas valve for a intertherm furance model no. mgh-055aacwl-06 ser.number mgh9009-00077
you need to contact your nearest a/c supply house. most company's that sale parts on line will not sale gas valves to the public due to liability.
May 15, 2014 | Intertherm P3RA-048K Air Conditioner
Intertherm MGH-075AAC burner cutting out before fan comes on
If you have a combustion air problem the flames will fade out instead of turning off abruptly. 15 to 20 seconds is a long time. if you are sure it is taking that long then it is not likely a flame rectification problem. If a limit is turning the flame off then it will turn off very abruptly like you turned off a switch. The evaporator coil situated above it may be dirty and in need of cleaning. sometimes however the limit switch will get to where it is shutting off at a way lower temp than it should. Limits are cheap enough and easy enough to just replace. DO NOT BYPASS THE LIMIT!!!!! You could burn your house down!!
Aug 28, 2017 | Intertherm Heating & Cooling
No problems, would like to find out the best way to remove blower for cleaning on an intertherm gas furnace mgh 075 ina mobile home
Generally ther is two screws at the base of the blower housing which hold it in place, remove the screws and pull, slide the entire assembly out. You will have to disconnect the electrical wiring to the blower and possibly the limit switch on the side if equip.
Aug 23, 2011 | Dayton Gas Furnace Heater
Intertherm MGH-056ABFC-91 won't kick on. Just changed thermocouple, gas valve, and thermostat this week. Changed fan motor, blower wheel, and limit switch last winter. Pilot is lit, thermostat is set. The...
At the furnace, jump the R and W (or T and T) terminals on the circuit board or gas valve. Make sure the door switch is closed with some electrical tape. By doing this we are forcing the unit to start. If it does fire, you have either a bad thermostat or a broken wire to the thermostat. If it does nothing, look for a bad fuse, check for 24 volts going to the gas valve, an open limit switch or 120 volts at the transformer.
Nov 02, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
102 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
