Window XPsp2 Dear whenever I try to shutdown my system,it get hanged in the beginning of the process and then I directly shutoff it from CPU
  • rajes08 Aug 19, 2008
    i have done it what u suggets but the problem still exists
  • 149 Answers
What so its just starts shutting down then freezes. check for viruses and memory dumps. scan pc for viruses. they could be cuasing it.
Posted on Aug 19, 2008
  • john doe
    john doe Aug 19, 2008
    did you try last known good configuration when it asks you. you might also have to do a system restore. have you added any new components/programs, or did this just start happening
MY SYSTEM IS HANG & AUTOMATIC SHUTDOWN IN A FEW SECOND
Please check your cpu fan properly connected and working or SMPS fan.
Jan 21, 2014 | Intel Computers & Internet
Screen pixelates and computer hangs
Test with another monitor or cable. You even have the option of testing on board video. Make sure to enable in BIOS.
Nov 10, 2012 | Computers & Internet
My processor is loose thats why pc hangs often! what to do?
Your PC get hang offen mean your memory is not sufficient to your processor to process to try to upgrade your memory , or else you have have virus in your system so that it high your cpu process so that too your PC get hanged. check your cpu speed by clicking ALT + CTRl + DELETE at same time, and check which program utilizing CPU more
Jan 02, 2011 | Intel D845GVSR Motherboard
Direct shutdown problem
Hello Friend,for resolving your problem first of all scan your pc with updated antivirus for any virus or spyware/malware it may solve your problem. If still you have problem then there may be a hardware problem check your CPU fan if it not working then change it because of heating of CPU there is shutdown problem otherwise there mat be power problem in CPU powering unit check it if problem found immediately change it ok???
Hope this may solve your problem try it and reply positively...
Jul 07, 2010 | Microsoft Windows XP Professional With...
My acer aspire 4315 hangs during shutdown. windows XP OS
This happens when there is a process still trying to work in the back end.
Try to disable most of the applications which get opened by default when windows starts.
Click on start/run/ and type msconfig. Once the window comes up click on start up tab and disable all.
Now try to reboot the system.
Also hope there is no usb device connected at the time of shut down. This would also make xp hang.
Thanks
Mar 01, 2010 | Acer Aspire 4315 Notebook
Hello, My mouse plugged into any usb port after 2-9 minutes from start up stops working. None of my usb ports will work until I reboot, then the problem repeats again in 2-9 mins. Oddly enough...windows...
Try hitting ctrl-alt-delete exactly once bringing up the Windows task manager.
Click on "processes" tab.
Look for processes that are hogging the CPU. Check the "system idle" process and it should be around 90%. If it is way less as the thing starts to fail, find which of the processes is hogging the CPU. Analyze which and why. This could be a virus-like thing even or a "memory leak" where mermory is not properly returned to the available pool when a program terminates.
Jan 26, 2010 | Dell Latitude C610 Notebook
My desktop PC Windows XP Pro hangs during resart only
try to use msconfig (on run) to see what programs run on system startup. some of these programs may be a malware that keeps on placing trash on your computer. i would recommend you download the Anti Malwarebytes and run it to remove the suspected malware.
regards.
Jul 15, 2009 | Computers & Internet
When i try to shutdown my system it give small **** as if ready but my wallpaper still appears for 2min and i even stll find time to repeat the action of shuting down for 2times at minimum can u pls give...
It seems like you may have some kind of program running in the background that refuses to shutdown.
Try pressing control + alt + delete and click on 'task manager' when you try shutdown and it's hanging.
Then click on processes tab and see what process is taking up the most CPU or Memory percentage.  Then highlight that, and right click and end process.
May 20, 2009 | Dell Microsoft Windows XP Home Edition
Installing new OS
Every laptop is accompanied by a preinstalled vesion of Windows, on the same hard disk in a hidden space. So if you get a prompt to restore your laptop to a previous state at the beginning of system startup, press the relevant key. If windows xp is your choice. and want to install it you may need follow the installation instruction from your system manufacturer. When the system starts up some information is displayed on the screen, like this: " Press F1 to enter setup" If you press the relevant key and enter the BIOS setup you can find the CPU temperature settings, shutdown temperature etc... This may not be you case. So I suggest you to get support from a qulified technician. Your system hardware should have some problem. (motherboard or hard disk is more prone to error) you can also try to find information from your system vendor's manuals and support website. All the best
Oct 03, 2007 | IBM ThinkPad A21m 2628 Notebook
Computers & Internet Logo
David Payne
David Payne
