Question about Canon Office Equipment & Supplies
Canon problem canon machina ir 5055n give erroe E225-001 i check connector and replace scanning lamp and inverter PCB and reader cotrooler PCB but it still give the error plz help
  • mohamed mohamed Aug 20, 2008
    thanks
    but the error not going i ching the platen glass but still idicate
  • mohamed mohamed Aug 21, 2008
    it the same one and new still the problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
The problem may the platen glass!!!!!!!!!!!
is the platen glass ok, did you change it? is the white on the platen ok? it uses it for reference.
Posted on Aug 19, 2008
  • CheckitRight
    CheckitRight Aug 20, 2008
    Yes, exactly are you sure it's the correct one???
    compare to the old one and see if there is a difference, is it original or aftermarket?
  • CheckitRight
    CheckitRight Aug 21, 2008
    just out of curiosity did you check the fuser for the lamp?
    also, sounds weird but try this unplug the finisher and see if it comes up.
    E225
    Insufficient light intensity of the scanning lamp: A specific level cannot be attained for the signal during CCD gain correction.
    Did you check the voltages : outlet, inverter pcb, ???
E-000711-0001 in canon ir 3300 xerox
The connector has poor connection. The ADF controller PCB is faulty. The finisher controller PCB is faulty. The DA unit PCB is faulty. The card reader PCB is faulty.
Connector, ADF controller PCB Is the interface cable between the ADF controller PCB an the reader controller PCB normal? NO: Correct the cable. YES: Replace the ADF controller PCB.
Dec 31, 2017 | Canon Office Equipment & Supplies
Ir 3300 copier error code e000732-0001
Canon iR3300 Error Codes Code: E732-0001
Code
E732-0001
Description
A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
Causes
The connector has poor connection. The reader controller PCB is faulty.
Remedy
1. Connector, Reader controller PCB Is the connection between the connector J1014 on the main controller PCB and the connector J409 on the reader controller PCB normal? NO: Correct the connection. YES: Replace the reader controller PCB.
Below is the site this came from which lists all the error codes in case another occurs after you resolve this one
Canon iR3300 Error Codes List page 1 from 12
Aug 27, 2016 | Canon Ir 3300 Black & White Copier
How to clean error code E000732-8888 for canon IR C5185
E732 Reader communication error.
Check the connections between the reader controller PCB and main
controller PCB. Check the power supply of the reader.
Mar 11, 2015 | Canon irc5185i
What does the Canon IR8500 error code E000222-0000 means?
There's no code like that in my manual.It's220-001 means lamp inverter PCB faulty,or reader controller PCB faulty. There's also a E 225-000 error which mean scanning lamp(xenon tube) is faulty,or inverter or CCD
Oct 14, 2014 | Canon Office Equipment & Supplies
Canon iR 6000 is giving error code E000225-0000 solution please
Scanning lamp faulty,inverter PCB faulty,reader controller PCB faulty...
Sep 25, 2014 | Canon Office Equipment & Supplies
When I turn on mu canon IR 6000 copier, it boots to a certain level then display code Eoooo225.
The scanning lamp (xenon tube) is faulty. The inverter PCB is faulty. The CCD/AP PCB is faulty. The reader controller PCB is faulty.
A specific signal level cannot be attained by CCD gain correction at power-on.
Jan 09, 2018 | Canon imageRUNNER 6000 Copier
Giving an erro E220(IR3300)
E220
0001 A fault is detected on the inverter PCB for the scanning lamp.
Main cause The inverter PCB is faulty. The reader controller PCB is faulty.
Action
1. Wiring
Is the wiring from the scanning lamp to the reader controller PCB normal?
NO: Connect the connector firmly, and correct or replace the wiring.
2. Inverter PCB, Reader controller PCB
Try replacing the lamp inverter PCB. Is the problem corrected?
YES: End.
NO: Replace the reader controller PCB.
Aug 02, 2010 | Canon imageRUNNER 2200
WHEN I SWITCH THE COPIER IR 2800 .IT SHOW;S ME ERROR E000220-0001 HOW DO I CLEAR THIS ERROR
E220
Action
1. Wiring
YES: End.
Pls. rate
May 11, 2010 | Canon Office Equipment & Supplies
Canon error
We do not work for FixYa.... This a free web site to answer questions you may have FOR FREE. I DO NOT GET PAID FOR THIS INFO........ OK, on the same page????? I have had this problem before, I, also ordered a lamp and the pcb and it did not work as well. I had to take a lamp and pcb from a working copier of the same mode to finally solve the problem. Try that first... It could also be a problem with the CCD unit?
Aug 20, 2008 | Office Equipment & Supplies
169 people viewed this question
old marine
old marine
