Question about Lexmark Office Equipment & Supplies
I am trying to connect my lexmark 4800 wirelessly and when I get to the part when they ask me to enter my WPA password the "continue" section will not light up
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Ahh..that's on your wireless configuration for your modem, not the printer, unless you have some printer server installed.
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
Upluged router to move it and lost "Secure"
Welcome to fixya
Please follow the steps to make the wireless network private
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts
Thanks
Vote me if you find my suggestion helpful
Apr 25, 2011 | Linksys Wireless-G WRT54G Router
Hot to secure my router from my neighbors using them. thanks
click this link to open the router login http://192.168.1.1/
When asked for username use admin and password leave it empty
then goto
SETUP -> WIRELESS SETUP -> MANUAL WIRELESS CONNECTION SETUP -> WIRELESS SECURITY MODE and select "Enable WPA > WPA -> WPA Key -> create your own password and save now if you want to access the Wireless connection you will have to enter the WPA key you just created.
Apr 11, 2011 | D-Link DIR-600 Router
Where do i find the wpa on my modem?
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
Read more: http://www.brighthub.com/computing/smb-security/articles/44810.aspx#ixzz1FOMsyJkq
Mar 01, 2011 | Video Game Consoles & Games
Hi, I'm trying to secure my wireless connection
Connect a LAN cable from the Linksys to the LAN port on yourcomputer, open a browser and enter the Linksys configuration URL -
http://192.168.1.1
The default login = admin
The default PW = admin
You can now change the admin password and configure the wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 01, 2011 | Linksys Wireless-G WRT54G Router
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
Jan 02, 2011 | Video Game Consoles & Games
Error code 051099-1
This seems to be a problem with your wireless router. Check to make sure you put in the proper WEP/WPA Security Code. If you aren't sure what I'm talking about...
Jan 01, 2011 | Nintendo DSi Blue Console
When i connect i get this message' your wpa key you entered may not be correct"
Jan 01, 2011 | Sony PlayStation Portable (PSP) Console
Hi i want to have internet on my PSP but it says type your wpa key and i dont know it.
It's a bit different for each router but I can show you how it would look in a regular setting:
Jan 01, 2011 | Sony PSPgo White Console
My wireless connection is unsecured I'm using a Netgear router,what do I do to secure my line?
1. Goto your web browser
2. Type 192.168.0.1 or 192.168.1.1 (depending on which Netgear router, just try both).
3. Type "admin" for username and "admin" for password.
4. Click on "Wireless settings" on the left frame of the router setup page.
5. Security options are on the main frame of the page now (under security options). Click on WEP and enter a WEP ID (make it unique).
6. Click on "Apply" and repair your wireless connection. It should prompt you for a WEP key.
Hope this helps,
Bill
Sep 05, 2009 | NetGear WGR614 Wireless Router
100 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
