Question about Intel Motherboard
Bios problem Displayed on MASSAGE CONFORMATION The system intruded,chachis opend or tempered before,please the system check.
    Scholar:
  • 125 Answers
Check the pc cover switch. There is a probably a little switch that senses when the pc cover is removed.
If the switch is not there, you should jumper the pins on the motherboard.
Posted on Aug 19, 2008
SOURCE:
System intruded chassis opened tempered before
go into the bios and there u can disable the tempering off
Nov 22, 2013 | ASUS Computers & Internet
"the system intruded chassis opnened
The NRL_LS has a connector for a microswitch on the case, to detect if the case is opened.
Look for jumper J2, between the battery and the bios chip, at one end of a long connector CON1.
There should be 2 adjacent bare pins at one end of J2.
Place a jumper block on them, and the system should start normally.
The manual is here +NRL-LS Cover.P65 - ftp.asus.com.tw
Look at item 9 on page 2-22, referring to jumper J2
Feb 09, 2011 | ASUS NRL-LS Motherboard
The system intruded , chassis opened or tempered before
Some computer display this message when the case has been opened. After installing components in your computer and closing the case/cover then go into the BIOS setting and reset the chassis intruder detector.
Feb 01, 2011 | ASUS P4B533-VM Motherboard
The system intruded.chassis opened or tempered before please check the system. what shall i do ?
When you open the computer case, a switch is tripped and after the case has been closed and the computer boots up, you get this chassis intruded message.
To clear this message go to the BIOS configuration and then to the chassis intruder detect and then Reset this setting.
Oct 03, 2010 | ASUS P4SE Motherboard
A massage display when started pc - chasis intruded, fatal error
enter the BIOS and turn of the chasis intrusion warning.
Jun 06, 2010 | ASUS P5GC-MX/1333 Motherboard
System intruded, or tempered, or the chasis are opened before. please check the system
There is a chassis switch that detects when the desktop case has been opened. You can reset this switch in the BIOS configuration so that this message doesn't appear until the case is opened again.
Oct 31, 2009 | ASUS P4SE Motherboard
Hello
There is a setting in the bios to turn off the chasis intrude alert. I don't know what board you are using, but usually enter the BIOS by tapping 'DEL' or by pressing F2 immediatly after switching on.
You obviously are a stranger to the BIOS, so "DO NOT CHANGE ANYTHING ELSE THAT LOOKS LIKE IT COULD DO WITH CHANGING" while you are in there, just look for and alter tis setting and NOTHING ELSE...
BluRay
Sep 07, 2008 | ASUS P4S800-MX Motherboard
Problem at boot
There is a mechanical switch connector available to determine if someone has opened the chassis.
You can bypass this through the BIOS by entering the BIOS on bootup (DEL? message at bootup? F1?) then look for the system chassis intruder alarm and DISABLE
Another option is to find the pins that the switch is supposed to be connected to (documentation on the ASUS P4B motherboard) and jumper them.
Jul 03, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Problem at boot
plz disable the chassis open warning option in the bios.
Apr 21, 2008 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
