Question about Microsoft Xbox 360 Console
360 Xbax when on have audio no video
  • 1 more comment
  • calicocajun Aug 20, 2008
    I have sound and a red picture.Please Help.
  • rsk1315 Aug 20, 2008
    i have the same problem i thought it was the wires, so i bought new ones. turns out it wasn't still dont work i get sound no picture
  • Coolkanisth Aug 22, 2008
    When Iwas Playing Game In My Xbox 360 the screen suddenly glitches and then display disspaears .Now there is no display but have sound . hwen ever i put agame in it it starts and emmits the in game sound but with no picture . help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
  • 344 Answers
Hello!
This is similar to the Red Lights Of Death. But instead of your CPU having a bad connection, it's your GPU. There is a 3 year warranty on the 360, so call Microsoft and get it repaired or replaced. If the warranty seal is broken you can take it apart and replace the x-clamp with 4 screws, 8 fiber washers, 8 steel washers and heat sink paste. Contact me for further instructions if doing it yourself. I hope this helps.
Good luck and happy gaming!!
Posted on Aug 21, 2008
Tip
Play videos on Xbox 360 and stream videos to Xbox 360
How to play videos on Xbox 360 and stream videos to Xbox 360 – including Blu-ray, DVD movies, and videos in various file formats
This tutorial intends to list out all the video formats supported by the Xbox 360, and explains all the available ways to play videos on Xbox 360 in HD quality or stream videos to Xbox 360. The videos include Blu-ray movies, standard DVD movies, and various other videos, such as ISO image file, Camera footages, MKV, MTS, VOB, M2TS, TS, TP, FLV files, etc.
Let's Get Started.
Part 1: The details of Xbox 360 supported file formats
1. AVI:
File Extensions: .avi, .divx
Containers: AVI
Video Profiles: MPEG-4 Part 2, Simple & Advanced Simple Profile
Video Bitrate: 5 Mbps with resolutions of 1280 x 720 at 30fps.
Audio Profiles: Dolby Digital 2 channel and 5.1 channel, MP3
Audio Max Bitrate: No restrictions.
2. H.264:
File Extensions: .mp4, .m4v, mp4v, .mov
Containers: MPEG-4, QuickTime
Video Profiles: Baseline, main, and high (up to Level 4.1) profiles.
Video Bitrate: 10 Mbps with resolutions of 1920 x 1080 at 30fps. Audio Profiles: 2 channel AAC low complexity (LC)
3. MPEG-4:
File Extensions: .mp4, .m4v, .mp4v, .mov
Video Profiles: Simple & Advanced Simple Profile
4. WMV:
File Extensions: .wmv
Container: asf
Video Profiles: WMV7 (WMV1), WMV8 (WMV2), WMV9 (WMV3), VC-1 (WVC1 or WMVA) in simple, main, and advanced up to Level 3
Video Bitrate: 15 Mbps with resolutions of 1920 x 1080 at 30fps.
Audio Profiles: WMA7/8, WMA 9 Pro (stereo and 5.1), WMA lossless
Notes: You can not mix and match the video and audio codec outside of the above defined lists randomly.
Part 2: Different ways to play videos on Xbox 360
With regard to playback videos from a USB storage device, please note that the Xbox 360 will support as big of a storage device as you can format using FAT32, and the maximum size of any single file on FAT32 is 4GB. Besides that, the maximum file size for an AVI, MPEG-4 Part 2, and H.264 file that can be played is 4 GB as well. To play a file greater than 4GB on Xbox 360, you can use Windows Media Player 11 and the Zune software to stream videos from your PC to Xbox 360 console, and notice that the file format must be WMV only. Why is it so special with a WMV file? That maybe WMV is a codec developed by Microsoft.
Well, that is to say, to some extent, we can consider WMV as the optimal format to play or stream to Xbox 360. When you are gonna watch a Blu-ray/DVD movie, or an MKV video, or some files else that are out of the range of Xbox 360 workable formats, what is your solution? We usually make use of Pavtube Blu-ray Video Converter Ultimate to do format conversion. Why do we choose it? Mainly because of its splendid output quality and its feature of an all-in-one application: a Blu-ray ripper, a DVD ripper, and a versatile video converter.
Part 3: How to convert Blu-ray/DVD and videos to WMV for play/stream on/to Xbox 360
We have mentioned in the above contents that the program we will use is Pavtube Blu-ray Video Converter Ultimate. Go to find a step-by-step instruction from the following part.
STEP 1: Load Blu-ray, DVD or other video files into this program
Click "Add Video" to import video files, and click "Load DVD" to import Blu-ray or DVD files.
STEP 2: Select subtitle and audio track
Click on the pull down menu after "Subtitle" and "Audio" respectively to select your needed subtitle and audio track as your choice. Your selection can be reviewed in the preview window to the right hand of the main interface.
STEP 3: Select WMV as output format for Xbox 360
Click on the drop-down list at the opposite side of "Format", and then choose "WMV3 (WMV9) (*.wmv)" as output format.
STEP 4: Do optimal settings for the output WMV files
Click on "Settings" button, and afterwards you can adjust audio and video parameters including video/audio codec, resolution, video/audio bit rate, frame rate, sample rate and audio channel on the popup window. To make it excellent for playback on Xbox 360, you can follow the optimal settings as below:
Video codec: wmv3 (the default one)
Resolution: 1920*1080
Bitrate: 150 kbps
Frame rate: 30 fps
Audio codec: wmav3 (the default one)
Sample rate: 48 khz
Bitrate: 320 kbps
Channels: 5.1 Channels
Do remember clicking "OK" button to confirm your settings.
STEP 5: Click "Convert" button to start BD/DVD ripping or video conversion
Once finished, click "Open" button at the bottom to get the output WMV files for Xbox 360, which now is prepared for playback or streaming.
Part 4: How to stream videos to Xbox 360
Well, as we have mentioned in Part 2, there are at least four ways to stream videos to Xbox 360, from Windows Media Center, Windows Home Server, Windows Media Player 11, and Zune Software. Actually, lots of online articles have detailed the setups and operating steps, just check the following links to find the one which is most suitable for you:
How to stream videos to Xbox 360 via Windows Media Center
How to stream videos to Xbox 360 via Windows Home Server
How to stream videos to Xbox 360 via Windows Media Player 11
How to stream videos to Xbox 360 via Zune Software
on Apr 06, 2010 | Audio Players & Recorders
Hi im trying to watch a show on my xbox and it keeps coming up with status code 69-c00d36be???
There are many correct answers to this question. Here's one...
I suggest you use mencoder or ffmpeg. Neither are really well documented, so you need to tinker.
A simpler, more expensive answer is to use TMPG Enc 4.0 Express. I purchased and use it daily.
-- from the xbox web site:
**1. What exactly does the Xbox 360 support for AVI?
Xbox 360 supports the following for AVI:
· File Extensions: .avi, .divx
· Containers: AVI
· Video Profiles: MPEG-4 Part 2, Simple & Advanced Simple Profile
· Video Bitrate: 5 Mbps with resolutions of 1280 x 720 at 30fps. See question number 11 for more information.
· Audio Profiles: Dolby® Digital 2 channel and 5.1 channel, MP3
· Audio Max Bitrate: No restrictions. See question number 11 for more information
2. What exactly does the Xbox 360 support for H.264?
Xbox 360 supports the following for H.264:
· File Extensions: .mp4, .m4v, mp4v, .mov
· Containers: MPEG-4, QuickTime
· Video Profiles: Baseline, main, and high (up to Level 4.1) profiles.
· Video Bitrate: 10 Mbps with resolutions of 1920 x 1080 at 30fps. See question number 11 for more information.
· Audio Profiles: 2 channel AAC low complexity (LC)
· Audio Max Bitrate: No restrictions. See question number 11 for more information.
3. What exactly does the Xbox 360 support for MPEG-4 Part 2?
Xbox 360 supports the following for MPEG-4:
· File Extensions: .mp4, .m4v, .mp4v, .mov
· Video Profiles: Simple & **Advanced Simple Profile
4. What exactly does the Xbox 360 support for WMV (VC-1)?
Xbox 360 supports the following for WMV:
· File Extensions: .wmv
· Container: asf
· Video Profiles: WMV7 (WMV1), WMV8 (WMV2), WMV9 (WMV3), VC-1 (WVC1 or WMVA) in simple, main, and advanced up to Level 3
· Video Bitrate: 15 Mbps with resolutions of 1920 x 1080 at 30fps. See question number 11 for more information.
· Audio Profiles: WMA7/8, WMA 9 Pro (stereo and 5.1), WMA lossless
5. Can I mix and match the video and audio codecs outside of those defined in questions 1 through 4 above?
No you cannot. We only support each audio and video codec in the explicit containers defined in questions 1 through 4.
6. How can I determine if a video file that I am trying to play conforms to the specifications as laid out in questions 1 through 4?
You can use a 3rd party tool to analyze your video files to determine what audio and video codec is used. A popular 3rd party tool to analyze video files can be found athttp://www.headbands.com/gspot/.
7. How do I create WMV, AVI, H.264 and MPEG-4 content? What encoders does Xbox 360 support?
You can create this content on one of many 3rd-party applications. Xbox 360 supports many popular encoders. Specifically for encoding to WMV you can use Microsoft Expression Encoder or Windows Media Encoder.
**8. What specific features of Mpeg-4 Advanced Simple Profile does the Xbox 360 support?
The Xbox 360 supports Bidirectional Frames (BVOPs), Interlaced Frames, Quarter Pixel Motion Compensation, Global Motion Compensation, and MPEG Quantization.
9. What are the different ways to play video content on Xbox 360?
You can play video from a USB 2.0 FAT32 removable drive, optical media, and by streaming from the Zune software, Windows Media Player 11, or Windows Home Server.
10. What are the different video codecs that are supported in all the different ways to play video content on the Xbox 360?
See table below for more information:
on.
Jun 30, 2011 | Video Game Consoles & Games
No audio
if possible use the hdmi as a video feed and non-hdmi as a audio feed i am not sure if hdmi even carrys sound.45687d7.jpg
Jun 27, 2009 | Microsoft Xbox 360 Console
New HDTV.. xbox 360 has no audio but has video
alright. make sure that your red, green and blue are all plugged in properly and that your audio plugs are also in there correct plugs. i think audio is red and yellow. correct me if im mistaken
Jun 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 has audio but does not have video
check the hdmi setting on the underside of your audio and video cable. the connector that goes into the xbox.
Jun 05, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
How to get video/audio input from Xbox 360 & digital cable input
Hook them all to the tv and with audio out from the tv run that to the bose 321.
Mar 14, 2009 | Bose 3·2·1 II System
XBOX 360
Your tv could have a losse connection on the video input. Try moving it around to see if you get any picture. Either that or u need a new audio video cord for your console
Feb 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
108 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
