Question about Minolta EP4000/5000 CS/PRO Copier
Problem in minolta cspro 2050
I need the code list of 2050 with their solutions without any premium.
  • 2 more comments
  • finfez Oct 31, 2008
    my iis showing "call your Technical Rep, code c0200"
  • deltahomecar May 15, 2009
    I have the error code C0991, Call Technical Support
  • Anonymous Mar 15, 2014
    waht mean ?
    m2 error
Code c0520
code c0500
Posted on Sep 28, 2008
  • Minolta Expert
  • 1,326 Answers
What code are you looking for??? I'll tell you what it means for FREE.....
Posted on Aug 20, 2008
Hi, i've found this for the konica minolta 2050
code c0500 Fuser problem. warm up incomplete
code c0520 High fuser temperature
i hope this might help you
Posted on Nov 23, 2008
  • sergiovf Nov 23, 2008
    sorry man i didn't see the first error code , here it is.
    code c0200 corona problem
Ola amigos alguien me puede decir como limpiar la rejilla de la ep 2050 cspro
Posted on Jan 16, 2014
What is problem c0f10 in minolta 2050
Posted on Jul 21, 2013
How to remove 601 code photo copier Minolta CSPRO 4000
Scanner fault,open the front door upper left should see access cover, open press trouble reset if the code comes back replace
Parts that may need to be replaced
Scanner Motor M4
Power Supply Unit PU 1
 SCP Board PWB-F
 Master Board PWB-A
If you can find these parts you have a legacy Minolta analog copier not even digital
try this as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 08, 2016 | Minolta Office Equipment & Supplies
Cspro ep 2030 minolta copying rough in the morning, but okay in the afternoon, solution please
Sounds like the warm up controls are not opperating properly. Or it is in a very cold environment. The "fuser" that provides the heat required to "glue" the toner to the paper may be defective, or the connections to it's controller or the controller is defective. Temporary solution may be to leave it "on" overnight to keep it as warm as it gets in the afternoon. Will take more electricity. But eventually it will need to be repaired, or replaced with a lightly used equivelent. It may be less costly than repair.
May 07, 2015 | Minolta Office Equipment & Supplies
How to change transfer corona for CSPRO 2050
Remove the assy. from the machine one screw whole assy. comes out. It is right below the drum, and has two white end assy.'s then remove old wire and replace them with new ones be careful not to lose the springs and be careful not get a knot in the wire be care replacing they are very fragile.
Jun 20, 2014 | Minolta EP4000/5000 CS/PRO Copier
Detaile of Code of Minolta Ep 6001 coper
pleas send me cs pro 6001 code 611 salvation
Feb 12, 2011 | Garden
Minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
May 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Feb 06, 2009 | Minolta Di3010 Copier
CSPRO 2050 PHOTOCOPIER
May 03, 2008 | Office Equipment & Supplies
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
931 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
