Question about Brother Office Equipment & Supplies
Machine error 76 - Brother Office Equipment & Supplies
  • 134 Answers
Error 76 is a fuser error, sometimes it can be reset in service mode, but usually the fuser needs replacement.
Posted on Aug 19, 2008
We have enjoyed a Rheem Thermostat and a Paloma Eco Sense tankless gas water heater #RTG-74XN-2 for 2 and 1/2 years, but now there are error codes flashing and resetting the thermostat doesn't hold. ...
Before calling service technician, open following links for Rheem troubleshooting resources, including generic error codes and contact information for Rheem and recent manuals:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://www.fixya.com/tags/rtg_74pvn
Error codes are start place for troubleshoot, and multiple error codes can indicate bad PC board.
Same error code on one machine can be different cause and solution than another machine.
Error 76 is usually communication problem with remote control.
Disconnect wires from machine, and clean terminals is a start point.
Wire between machine and remote might be bad, or remote control is bad, or PC board or wiring connections are bad.
The problem might be solved by having technician catch the machine up on yearly maintenance.
Manual for same-similar product shows maintenance and troubleshooting and a few error codes, but not 76:
For the most part, the manual recommends calling service technician instead of offering DIY details.
http://waterheatertimer.org/pdf/DirectVentManualRTG-74PVN-1.pdf
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 05, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
Error Code 77 on brother 4100 fax intelifox business class
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
Brother DCP1200 Machine Error 76
This refers to a error with the fuser temperature you need it repaired by a service technician. Parts can be as little as $15 for the thermistor sensor or as much as $100 for a new fuser.
Jan 04, 2010 | Brother DCP-1200 Laser Printer
Machine error 76 is appearing
Error 76 is a fuser error, you can try going in and out of service mode, press the following key combination all within 2 seconds " features or function , * , 2 , 8 , 6 , 4 , " if done fast enough the all the lights willl be flashing. Them exit out of service by pressing 99. If the error returns after startup the fuser will have to be replaced.
Oct 28, 2009 | Brother IntelliFAX 4100 Laser Fax
Will not receive fax Will not send fax Will not copy Has error Message 76 on monitor
Machine error 76 is a bad fuser lamp.Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
May 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother MFC-8600 What is Machine error 76?
Machine Error 76 - fFxing Heater Harness Disconnected or Broken. Solution: replace Fuser Unit
Jun 11, 2008 | Brother Office Equipment & Supplies
Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
Apr 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Jan 18, 2008 | Brother IntelliFAX 2800 Laser Fax
How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Nov 29, 2007 | Brother MFC 9600 All-In-One Laser Printer
418 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
