Hi signashuff,
Sounds like you are on the right track. Since all seems to be working and you can hear gurgling, i.e. steam being made, then the the passages are plugged. The vinegar and water trick will clean the reservoir, but you still have to clean all the openings in the ironing surface. Have you done that?
Another vinegar trick to try is mixing hot water, vinegar and baking soda and pouring that into the iron while it is still frothing. Let the iron sit for 30 minutes on the soleplate with iron on steam. Then run some clear water through it and use it on a fabric you don't care about for the first session.
If that doesn't work, you might try a commercial cleaner such as CLR, Faultless Hot Iron Cleaner, Whink Steam Iron Cleaner, or Lime Away.
Distilled water is good to use in your iron but it still has minerals in it that will build up over time. It just takes longer to build up than tap water.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Keeps me working here. :>)
Thanks,
Handie Andie
Oh, I'm sorry, this was posted as an iron...
Have followed all the directions in your owner's manual? On page 12 there are instructions for clearing the internal piping by pouring the vinegar solution into the hose connector and letting it sit for 40 minutes before draining.
If this does not do it, then we would have to look at the heating temperature.
Do you get any steam at all?
If you don't and you hear it gurgling, then there must be a blockage.
Good luck.
Andie
Glad that worked for you, Signa. Here's the manual: http://www.topinnovations.com/steamfast/...
Copy and paste this address into your browser's address bar and it will open right up for you.
Thanks for visiting with us here at fixya.com!
Andie
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
This is a steamer, not an iron, no sole plate. ( just like above picture)I had it farther apart. took a plastic hose loose and cleaned a little residue out. I don't think it is plugged. I wonder if it is not getting hot enough. It has not been heavily used. Any more suggestions?
Thanks Andie, I will try that. I don't have the owner's manuel, as this was given to me without. Thanks for the instruction. Will let you know.
Signa
The cleaning maintenance you advised me to do (which I would have tried had I had the manuel) WORKED! I now have lots of steam. Thank you for your patience and advice. Well worth the $6 I spent. One more question: Can I download a manuel anywhere? I tried a search before, that is how I found you.
Thanks again,
Signa
