Probably too simple to be true .. but I have a 'record player' in an old car, and the small motor that drives the turntable is running in reverse (incorrect) direction. Is thi simple a matter of 'polarizing' or some such thing. Probably simple to you , but well .. I need some advice and would appreciate it. Remember this is a tiny motor .. 12V , 1 1/2 " dia ... Thanks for you help Ed 313 399-5110
    Brigadier General:
  • 6,966 Answers
I agree, it is old. None the less, yes on reversing the wiring of the motor. All DC motors are polarity affected.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
SOURCE:
Califone 1435k This record player from the 70s runs great and came highly recommended but the 33 records we're trying to play are sounding much too fast. Any ideas on how to fix this?
This is an idler wheel drive turntable that uses a small rubber wheel, that when engaged pushes on the motor spindle and also on the rim on the underside of the platter. The spindle on the motor is stepped so as you shift speed the idler wheel moves up or down the spindle and that changes the speed of the platter. It could be the the shifting mechanism is dodgy You can try to loosen it by gently shifting the speed from 78 to 16 and back again. But the idler wheel rubber might be in trouble too.
Dec 29, 2016 | Califone International Audio Players &...
Hey there, After a power outage the motor that drives the platter "BSR turntable" does not function. Is there a fuse or some other likely suspect?
If the motor is directly connected to a mains supply then the chances are that when power was restored it burnt out or damaged the motor itself. Following the mains lead into the unit should answer where the power goes. If it goes to a transformer and it's associated power supply the problem will be found there.
Nov 07, 2016 | Audio Players & Recorders
Electro Brand model number 9801: I played one record, now when I tried to play another the turntable will not rotate. Could the motor have burned out that easily?
Listen carefully with your ear to the turntable when you move the tone arm towards the record. If you can hear the motor running and the turntable is still stationary then the drive belt from motor to turntable has probably fallen off of broken. Lift the turntable, there's normally a metal clip holding the turntable in place, and locate the drive belt.
Jan 19, 2014 | Teac GF-350 CD Shelf System
Turntable out of Tune
it will be the turntable speed not exact
quality turntables have bars all around the circumference and when the speed is correct under a fluro light those bars will appear as stationary or using a strobe light set at 50 or 60 cycles a sec
bars going anticlockwise are too fast and moving forward are too slow
quality tables have a small knob or screw to adjust motor speed
Jul 27, 2017 | TDK Tvt2002 Usb Belt-drive Turntable
I have a Technics SL-QL1 direct drive turntable that works perfectly for about 5 seconds, then it suddenly repeats itself over and over... the record never advances beyond that point. It happens with any...
I don't think it's the direct drive as that just makes the platter spin around. Since the stylus sits in a record which moves it forward, if it gets stuck then it's going to be something to do with the arm of the record player that can't move beyond that point. Check around the piviot of the arm for problems and look at the anti-skating control. If you can move the platter by hand that will prove it's not the drive if the stylus gets stuck.
May 25, 2011 | Technics Audio Players & Recorders
Hey guys I purchased the Stanton Str8-80 in 2003 and used it actively for the following 1 or 2 years. Shortly after that, I left it in a corner to collect dust and only recently, I started to use it again....
If the turntable has a belt drive, the belt probably has failed. If direct drive, the motor may have failed. Only a cheap turntable would have rim drive that failed. Your Stanton is not one of them.
Apr 26, 2017 | Stanton STR8-80 Turntable
I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Jul 24, 2010 | Crosley CR248 Turntable
Hi, When i try and record onto the machine it does not run, it sticks, tried new batteries but no difference, machine is about 2 years old, David.
If ther is no drive, even in fast forward or reverse, the the belt may have come off the motor pulley. Otherwise you may have a hair wrapped around the tiny drive cogs under the turntable.
May 04, 2010 | Philips Pocket Memo 381 Handheld Cassette...
I have a old antique wurlitzer and the records are playing very slowly what can be causing this
Bad drive belts.
Motor needs servicing (most likely).
Hasn't been converted for 50 Hz.
Dave F.
Nov 26, 2008 | Wurlitzer Jukebox 1015 One More Time...
 Grubhead
Grubhead
Marvin
Marvin
