Question about Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW
My freezer is hot!
My freezer freezes my food just fine, but I just noticed that when I touch the outside of the freezer on both sides that it's hot to the touch. Later, the sides are simply warm. I felt my refrigerator and it has sides that are cool to the touch. Why is my freezer hot?
  • 1 more comment
  • Anonymous Aug 20, 2008
    it gets hot behind the door seal on the freezer side.
  • bullte Aug 20, 2008
    on the freezer side of the refrigerator under the door seals the sides are getting hot. can you help
  • Anonymous Apr 20, 2009
    I have a Kenmore upright, frost free. I just notice that the sides (center portions) of the freezer is very hot. Is this normal.
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Posted on Aug 26, 2008
My 82L Upright Freezer from The Good Guys - a GVA is very hot on the outside - almost too hot to touch. Is this normal?
yes
the freezer works by taking the heat from the inside and exchanging to a coil that is under the outside of the freezer
It will be quite hot until such time as the inside temperature is brought down to the setting
the thing with freezers is that on start up the food that you are putting in should be cold to start with and not hot ( if necessary , use a bag of ice as a helper ) Later on any hot food added will not affect the operation that much as it is be in small quantities
this would be explained in the user booklet that was inside the freezer
Jan 09, 2016 | Freezers
Why are the sides of my frostfree freezer so hot?
check to see if you have a fan down by the compressor if so make sure it is running. if no fan you are starting to loose freon
Jul 25, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
The outside of the freezer sides are extremely hot to the touch? Why? Freezing fine on the inside.
the coil normally on b ack of fridges is on sides of freezers under skin it is normal to be warm. The hotter the weather the hotter the skin.
Sep 02, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have an upright Frigidaire freezer. The outsides (left and right) are hot to the touch. Is it a problem?
No. Instead of exposed coils on the back side, many (most) freezers place the condenser coils near the outer wall of the freezer to disipate the waste heat removed from inside the freezer. It will not be as noticable when the freezer is not running, and is completely normal.
Jul 09, 2009 | Freezers
Nor-Lake t3000 freezer - door HOT
The door frame heater is probably damaged and grounded. Unfortunately, it is still energized causing less than the entire heater being utilized which will cause an extremely hot condition. I would look at replacing it. It is a pain to do but with some patience, it can be done.
Good luck and hope this helps.
Mar 27, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
Side of frost free freezer is very hot
the condenser coils of the freezer anre inside the case of the freezer, they are suposed to be hot they are removing the latent heat from inside the freezer to make it cold, no heat transfer no cooling, you will notice the high heat temps a lot of the time after adding food to the freezer or when you just have started it after being turned off for some reason it is fine
Mar 27, 2008 | Frost Freezer WCWO F15WA FREE - POCKET...
Freezer is running constantly and sides and top are hot.
first whirlpool makes a good product as far as the sides being hot good sign the condensing coils are in the sides are supposed to be hot worry if its running and they are cold then not working right ok as far as running modern units useing 134a do have long run times but are not using but same enegry as 100watt light bulb otay
Dec 30, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Aug 07, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW Logo
1,101 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
