SOURCE: torque settings on 2006 street glide
the clutch(derby) cover torque is 96 in lbs
the trans side cover is 120 in lbs.
SOURCE: 2006 Harley Street Glide turn signal problems
hi, if you have not yet fixed the problem , the fuse box is located underneath the left sidecover in front of the left sattlebag youll need to remove the bag to get the side cover off ck the fuses thats all it should be ,prolly what happened was a bulb went bad and shorted the circut blowing the fuse for them theyre on the same fuse as the tach and speedo
SOURCE: 2007 street glide misses and wonts to stall out when taking off??
my roadking just did the same thing, check the gasket between carb and intake
SOURCE: My check engine light goes on sometimes and then
on your dash is the button to check your milage. push it in and hold it down until your codes come up. some of the numbers it will go through will only be ecm numbers
Testimonial: "exactly what I needed. Thanks,"
SOURCE: 2006 Harley Davidson street glide brake light
Try loosening the bolts holding the front master cylinder on the handlebars. Slide the master cylinder down as close as possible to the right handlebar switch housing. If this doesn't work, the front brake light switch is probably bad and needs to be replaced in the right switch housing.
Good luck
Steve
http://schematicsdiagram.blogspot.com/2011/12/heating-knob-light-bulb-under-dash.html
Parking lights, tail lights and dash lights
not working?
http://technoanswers.blogspot.com/2012/01/parking-lightstail-lights-and-dash.html
How to replace Instrument panel and dashboard?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
Tail lights and dash light fuse keeps blowing?
http://technoanswers.blogspot.in/2012/02/tail-lights-and-dash-light-fuse-keeps.html
This will help.
Thanks.
